View Poll Results: What is the better Headgasket
Cometic
10.00%
OEM
90.00%
Other.. Please explain
0%
Voters: 10. You may not vote on this poll
Cometic Vs. OEM Headgasket
Old Aug 12, 2010 | 07:48 PM
DezodDon's Avatar
Originally Posted by Crippie
does the fact that im going .5 overbore mean anything in the difference between the two gaskets?
The stock gasket looked really close to the bores as is. Going larger might cause the gasket to hang over into the bore a little bit. Cometic offers a 92 mm bore gasket which would give you the extra area around the bore for clearance purposes. If the bore center lines are off as well then this is a good choice. With an open deck block bore center lines can shift over time.
In a closed deck block it's more from over heating and poor casting and machining at the foundry.
Originally Posted by trd07tc
usually when a head gasket fails its caused by something other than the head gasket
Normally the HG fails due to excessive cylinder pressure normally caused by detonation.
The HG is the fuse of the engine much like the clutch is the fuse of the drivetrain. Would you rather have the head gasket fail or a piston?
Which is better depends on your application.
Old Aug 12, 2010 | 09:10 PM
trd07tc's Avatar
You missed my point. Everyone is sharing stories of headgasket failure - whether it be OEM or aftermarket. 99% of the time headgasket failure is caused by factors other than the headgasket. Whos to say in one situation where a cometic failed an OEM would have not?
Point is either will get the job done making either a good choice. If you have headgasket failure find out why instead of just replacing and blaming the gasket.
Old Aug 12, 2010 | 09:40 PM
Crippie's Avatar
1UP Crew
great info! from all of you.
Old Aug 12, 2010 | 10:23 PM
willerdcraft's Avatar
OEM i am sure toyota knows how to make a gasket that will not blow easily
BlackKnight
Sep 15, 2015 06:42 AM
253CSM
Jul 14, 2015 09:08 PM
goatbelly
Jul 12, 2015 10:13 AM
dixonge
Jul 11, 2015 11:02 PM
bluemex
Jun 16, 2015 03:22 AM
