Compression Test
Compression Test
Does anyone here know where i can find a basic guide to doing a compression test on my 2007 tc ?
i found many compression test guides but most are for other cars,
specifically for the tc what i need to know is what to disconnect to prevent fuel from spraying into the chamber when i crank the motor for the actual test itself.
a fuse maybe ?
i hear and read about everyone doing compression tests on there tc's but no one posts how it should be done "properly"
maybe im missing something, can you guys point me in the right direction please ?
thanks !
a fuse maybe ?
thanks !
Pull out the all the coils and plugs. Pick a cylinder and screw the tester into the plug hole You test one cylinder at a time. Now turn over the engine like your starting the car while holding the gas pedal down all the way for 3 seconds. Now check the reading. You should get about 180 psi. It should be even in all the cylinders. If one cylinder is low test it again. If your getting any low readings you should take it in for a leak down test.
Why do you think you need a compression test?
COMPRESSION TEST READINGS / RESULTS !
alright here are my readings from my compression test.
i did 2 tests.
the first test i cranked the motor about 8 - 10 times
the second test i cranked the motor about 4-5 times
Here are the First Test Readings
From Left to Right as you face the engine compartment -
Cyl1 : 200
Cyl2 : 197
Cyl3 : 210
Cyl4 : 200
that was test 1 where i cranked the motor about 8 - 10 times
now for test 2
Test 2 Results / Readings :
From Left To Right as You Face The Engine Compartment
Cyl1 : 190
Cyl2 : 185
Cyl3 : 184
Cyl4 : 182
iv'e been running a f*cked up turbo install for about 3 months now, i'd say compression is pretty good. i just cant get anyone to tune my bastard car properly.
anyways.. those are my readings
i did 2 tests.
Cyl1 : 200
Cyl2 : 197
Cyl3 : 210
Cyl4 : 200
now for test 2
Cyl1 : 190
Cyl2 : 185
Cyl3 : 184
Cyl4 : 182
coils phil are the black caps above our motor that connect to the spark plugs and provide spark to the spark plugs... their new modern name for the spark plug wires is called coil packs....
and yes a DIY with pics or video would be good!!!!
i did 2 tests.
Cyl1 : 200
Cyl2 : 197
Cyl3 : 210
Cyl4 : 200
now for test 2
Cyl1 : 190
Cyl2 : 185
Cyl3 : 184
Cyl4 : 182
i did 2 tests.
Cyl1 : 200
Cyl2 : 197
Cyl3 : 210
Cyl4 : 200
now for test 2
Cyl1 : 190
Cyl2 : 185
Cyl3 : 184
Cyl4 : 182
Your Compression is good. So, no problems there.
Originally Posted by Mr_Meaty
Hey...could you do a step by step on how to do a compression test along with what I need to buy from the store?
I may be showing my ignorance here, but where are the coils?
Now that I'm not sick anymore, I was planning on doing a DIY (video style) on how to do a compression test.
Side Note: You only need to remove the coil packs (Plug wires), and spark plugs from the motor to do your compression test.
So, by "Pulling the coils" you mean completely removing them from teh car? Or just disconnecting them from teh spark plugs?
And there is nothing else you need to disconnect to prevent fuel from spraying everywhere?
