a couple turbo questions
Old Feb 14, 2007 | 06:03 AM
blitzblue1032's Avatar
Scion Noics
Default a couple turbo questions
i am about to get a new turbo for my tc and i was wonderin if someone could possible tell me what else i will need to get with the DEZOD turbo kit. does it come with everything you need? also which gauges would i need to get? im pretty well a nOOb when it comes to turbos so any information would be very helpful. also, if neone that has the DEZOD turbo setup on their car could tell me about how much they paid for the turbo kit and gauges and tuning etc etc.. i would jus like a ball park figure of what im lookin at exactly. thanks every1.
Old Feb 14, 2007 | 06:06 AM
draxcaliber's Avatar
you'll need gauges (boost and air/fuel) clutch, colder spark plugs, engine management that should be all.
Old Feb 14, 2007 | 06:11 AM
rozz-tC's Avatar
^^ what he said, and make sure you run 93 octane gas
Old Feb 14, 2007 | 06:52 AM
Scion Noics
ok tyvm, would it still be a good idea to get it tuned even with emanage? also, what would be best brand spark plugs to get? and ive heard that you have to break in a turbo, could someone explain to me how to break in a turbo? lol sry for all the questions but i want to make sure that ive got everything right before i go f*in something up lol.
Old Feb 14, 2007 | 07:00 AM
rozz-tC's Avatar
the break in stuff should be with the install info, and yeah get a tune, ngk's are a good plug..and here is alittle on breakin in a turbo
http://www.boostplanet.com/new_page_2.htm
Old Feb 14, 2007 | 02:53 PM
jrodTc's Avatar
Thanks for the turbo break-in article. Quick question, in the article it says to use high quality NON-Synthetic motor oil. I know alot of people use Synthetic oil, now i'm confused of which type I should buy. Can someone give me the logic behind using Non-Synthetic oil for the break-in period? Thanks for your help.
Old Feb 14, 2007 | 03:01 PM
318_tC's Avatar
buy a boost gauge, a wideband, a oil press gauge
one step colder plugs
i use fully synthetic oil
emanage is fine to tune with
ur gonna run around 5g's im sure
Old Feb 14, 2007 | 03:23 PM
Scott8's Avatar
I thought synthetic would be better then regular oil???
Can someone elaborate???
Old Feb 14, 2007 | 03:37 PM
rozz-tC's Avatar
im not sure the logic behind it, ive always heard and used synthetic.
Old Feb 14, 2007 | 05:08 PM
rodlandscion's Avatar
here's what I did:
Dezod kit
colder spark plugs
fully synthetic mobil1
boost and air to fuel (wideband) gauge.
It wound up being around 5k and I still have this left to do:
Oil Pressure gauge
Greddy Pressure Sensor for tuning
Clutch
Boost controller
Turbo Timer
Emanage support for datalogging
Old Feb 14, 2007 | 06:36 PM
paul_dezod's Avatar
Scionetics
KAD
Our kit includes fuel and engine management, so as far as that is concerned, you're covered. I would recommend a clutch to help harness the power and a boost gauge w/ wideband O2 at minimum. The pressure sensor and harness will help with the clarity of the tune overall as well.
The kit itself is very comprehensive.
Old Feb 14, 2007 | 06:50 PM
Scott8's Avatar
Paul,
Which oil is recommended for brake in of the turbo?
Old Feb 14, 2007 | 07:10 PM
paul_dezod's Avatar
Scionetics
KAD
Originally Posted by Scott8
Paul,
Either Redline, Royal Purple, Mobil 1, Amisol....any full synthetic fluid will be fine. (assuming the proper weight and such for application)
Old Feb 14, 2007 | 07:31 PM
deathbyc4's Avatar
I'm using Amsoil 5w-30. Luckily I have a local race shop/BMW tuner that carries it.
Old Feb 14, 2007 | 09:12 PM
Simplyscion's Avatar
Team No Limitz
turbos and noobs dont go together...they mix just as good as oil and water
Old Feb 15, 2007 | 04:21 AM
Scion Noics
thanks e1 for yalls input and advice. now hopefully sometime within the next 2-3 weeks i will be boosted. does neone kno about how long the stock clutch would last considered it isnt beat to death? oh and as for the bit about turbos and noobs go together like oil and water, not exact quote but close enuf lolol, everyone has to start somewhere , ur not born knowing everything there is to know about turbos . lol sry, jus had to throw that out there
Old Feb 15, 2007 | 03:23 PM
JDsciontc's Avatar
Hey don't worry about that comment. just get your turbo kit and have a bunch of fun. you now know what you need to know. And i would invest in a clutch because the stock one will be shot in the matter of weeks depending on how you drive. i would go with a cc or zpi.
Old Feb 15, 2007 | 03:25 PM
Scott8's Avatar
I will agree with you that you aren't born knowing this stuff. That's why I think forums are a huge help with new projects.
Let's not jump down anyone's throat since they are new to the FI club, and can't we all just get along?
Old Feb 15, 2007 | 03:43 PM
jrodTc's Avatar
Hows that weather there in Il scott?!? Sorry man, just had to bust some ***** since its going to be 80 here today. I grew up in Illinois, so I feel your pain. Ok, back on topic. Synthetic oil it is.
Old Feb 15, 2007 | 03:46 PM
Scott8's Avatar
That was low
It stopped snowing, but now it is almost -20 with the wind chill
And I hate you for rubbing in the 80 degrees, but how's your taxes in California and the smog regulations treating you? <-- bustin' ***** right back
