cracked t-netics pipe
Old Nov 26, 2006 | 08:54 PM
PlayinWithFire's Avatar
Default cracked t-netics pipe
i got the turbonetics kit and the pipe goin up to the wastegate
how long do u think i can drive on this if at all?
Old Nov 26, 2006 | 08:56 PM
tikbhoy's Avatar
Default Re: cracked t-netics pipe
call them and they will replace it for free if its still under warranty
PM MIAPLAYA
Old Nov 26, 2006 | 09:13 PM
my issue is im supposed to go back to school tonight (from new haven to worcester - 1:45 hr drive) and i need to know how and how soon this can get fixed.
Old Nov 26, 2006 | 09:14 PM
tikbhoy's Avatar
2255 Agate Ct.
Simi Valley, CA 93065
Ph: (805) 581-0333
Fx: (805) 584-1913
www.turboneticsinc.com - Home Page
www.eturbochargers.com - Online Store
info@turboneticsinc.com
you could always fix it by welding it up but depending on how bad it is. but why rush fixing something and paying for it when you can get it fix'd. just try to hitch a ride with someone
Old Nov 26, 2006 | 09:18 PM
RSracer's Avatar
you can drive it like that, the only thing that will happen is exhaust gas will leak from it.
Old Nov 26, 2006 | 09:45 PM
Prototype_xB's Avatar
just avoid full boost until you recieve a replacement from them
Old Nov 26, 2006 | 10:45 PM
zer0's Avatar
Common problem it seems for the Turbonetics kit. They could have came up with a better design.. imo
Old Nov 26, 2006 | 11:55 PM
jam0321's Avatar
Talk to Ed or Steve @ Turbonetics tomorrow and they will have a new one on your doorstep by 10am Tuesday!
This problem seems to come most often when the installer fails to bolt up the support bracket to the block near the s-pipe. When the support bracket is not used or when the installer needed to use a lot of downward force on the downpipe to get the holes to line up, the added stress is applied to the flange near the wastegate.
Can you verfiy if the support bracket is used and was excess force required to get the bracket to line up correctly???
SloTC1
Aug 16, 2018 02:45 PM
RS2Blitz
Jan 15, 2016 09:42 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
JLOVE1
Jul 31, 2015 02:40 AM
