DEZOD MOTORSPORTS: ALPHA SERIES V-band Manifold Installed (Page 21)
Old Jun 27, 2010 | 12:47 AM
  #301
silvrtc300's Avatar
It's not about power.. it's about efficiency.. Just wanting to make sure i get a good spark on them plugs.. They work great though..
Old Jun 27, 2010 | 12:58 AM
  #302
brett561tc's Avatar
so you dont have a before and after dyno or anything? reason i ask is because i have picked up 30 whp on a dyno just from gaping the plugs different.
Old Jun 27, 2010 | 01:54 AM
  #303
silvrtc300's Avatar
Yeah regapping can gain a bit of power then index can help as well. And introducing bigger spark can too. It is being more efficient and frees up power. Just the little stuff added together gains some.. But its not a power adder... Turbo, supercharger, and nitrous are power adders.. im sure u knew that..
Old Jun 27, 2010 | 02:52 AM
  #304
m6ar2cel6oTC's Avatar
Mr. Bret what do you gap your plugs at now?
Old Jun 27, 2010 | 01:32 PM
  #305
silvrtc300's Avatar
Yeah what were you running previously.. That's quite a big jump of hp for just gapping plugs... .023" - .030" should be were u gap them.. on a boosted app.. but man i can't imagine gaining 30whp.. most average gains from most gapping, indexing, and increasing spark is minut.
Old Jun 27, 2010 | 01:47 PM
  #306
brett561tc's Avatar
yeah. i was looking at the hks dli to amp up the spark and get a complete mixture burn and maximize power. although, if the okadas work just as well i might go with them. its just the whole paying $800 vs $400 that im having trouble with.
to answer the other question about gaping, when i had the f/ic my gap on my ngk heat range 8 ir's was at sock gap which i believe was .028. we thought i might be getting some blow out, so we gaped them dow to .018 and bam, 30 whp. im planing on getting some ngk v power copper heat range 8 plugs before i go back to the track here soon and keep them at a stock gap.
Old Jun 27, 2010 | 03:35 PM
  #307
God damn .18. Lol damn I had mines at .30 and I thought that was pretty low. When I get my car running again I'll try tapping them at. 28.
Old Jun 27, 2010 | 03:44 PM
  #308
silvrtc300's Avatar
Yeah if ya got the Okada's you probably could get that result and not have to gap them that narrow..
Old Jun 27, 2010 | 04:31 PM
  #309
Damn so now your at .18? If you made more power on .18 why go to .28?
Old Jun 27, 2010 | 04:44 PM
  #310
brett561tc's Avatar
cause i have a feeling that the spark blowout had a lot to do with the f/ic. now that im on a standalone i should be able to run a wider gap and have a more complete burn.
Old Jun 28, 2010 | 02:44 PM
  #311
paul_dezod's Avatar
Scionetics
KAD
Thanks for sharing the awesome pics Dave!
Old Jun 28, 2010 | 06:12 PM
  #312
silvrtc300's Avatar
Yes. Thank you.. Any word of my other stuff..??
Old Jun 28, 2010 | 07:14 PM
  #313
paul_dezod's Avatar
Scionetics
KAD
Head is going through parts washing and full disassembly now.
Old Jun 28, 2010 | 08:20 PM
  #314
silvrtc300's Avatar
NIOCE... Thats what i like to see.. core should be going up to you guys soon..
Old Aug 27, 2010 | 01:25 AM
  #315
bluesciontc's Avatar
Ok Guys I know I haven't been posting in a while its been Hectic as all hell building the car getting it tuned and getting it race ready! Well any ways this is how it goes!!!
So we finally get the car all done up ready for tune!!! Dezod Alpha series with ASR Motorsports Charge pipes, Intercooler, and inlet pipe, RC 1000cc peak and hold injectors, Dezod/ASR one off Oil cooler setup, Hydra Nemesis stand alone, Dezod return fuel system with Aeromotive Fuel Pressure regulator, ASR S-Pipe back straight out the middle exhaust, VP C16 Racing fuel, Built Motor...
Well we got the car on the dyno here at Vinny Ten Racing went through some problems minor stuff nothing to worry about. We load tuned it for 2 days getting everything nice and smoot for when it was ready to make some wide open throttle pulls to see what this bad boy could do. We finally strapped it down for the final time to make some minor adjustments and to start making some horsepower. We started off at 14 psi we were making full boost around 3800/4000, and making some good numbers (380WHP with 420 WTQ), but thats not what we were shooting for we were looking for something around the 500-550 WHP range (its a time attack car ;)). So we bumped the boost up to 18 psi making a few runs and reving the motor to 7500 RPMS, we Made 420WHP and 460 WTQ at 18 PSI with the same spool time as 14 PSI (allso this may sound low for the GT3582R but just for you Ptuning fan boys out there this was b4 we touched the variable valve timing where we had 70 WHP sitting on the table at the same boost level). Well we were doing one more run b4 we touched the variable valve timing and all hell broke loose and when I say broke loose i mean broke loose. It ended up with a rod through the block of my motor . Now!!! this is not caused by the kit or the tune this is caused by ZPI D-Bags not doing what I payed them to do years ago (no big surprise there I know). I sent them Carrillo rods which where not in my motor they put stock rods back in and thats why the rod broke and took out my entire motor. It didnt even brake at high rpm it broke at 4700 right when peak TQ comes in and Says Hey whats up motor lets makes some MOF___in Tq b!tches. So low and behold thats all the numbers I have for you ringht now but it wont be to long till I have the motor back up and running with some nasty parts built here at Vinny Ten Racing and will have some serious HP numbers for ya. BTW I already have a new motor ;)
Old Aug 27, 2010 | 01:43 AM
  #316
I hope Jenny stickler gets ran over a scion tc with a zpi doo doo turbo kit. Either way nice numbers for what it's worth. ANd gl with the build!
Old Aug 27, 2010 | 01:44 AM
  #317
Have any ids of the pull when the rod went through?
Old Aug 27, 2010 | 05:53 AM
  #318
Nah I dont have any our computer actually crashed so everything was loosed it sucks ___. But the curve was amazing smooth and power was coming on strong.
Old Aug 27, 2010 | 06:47 AM
  #319
MnTc's Avatar
noob question but how would this turbo run with just 10psi ?
Old Aug 27, 2010 | 09:49 AM
  #320
efficiency doesn't start till 14 psi
