Did some maintnence on the tC today
Old Jul 19, 2009 | 06:42 AM
gingles's Avatar
next time prime your turbo if its a fresh install......its very important to get oil to it asap
Old Jul 19, 2009 | 11:03 AM
rhythmnsmoke's Avatar
Music City Scions
Originally Posted by Syldrin
and no i didnt prime the turbo i just turned it on and let it idle for a minute.
Turbo should be primed even on oil changes. Otherwise oil could seep past the seals and into the piping, including exhaust. Which would also cause smoke out the tail pipe. If compression is good, rings should be good, so 98% sure your rings are fine. I vote oil in the piping from the turbo.
Old Jul 19, 2009 | 04:22 PM
Windu's Avatar
By the way, if you can do a compression test, then you can do a leak down and no need to drive anywhere to get it done. Only difference between the two, is you drop a little oil in the spark plug hole, and follow the same instructions as you would for a compression test.
Um....NO. Leakdown uses a different guage set and compressed air.
Old Jul 20, 2009 | 01:32 AM
Syldrin's Avatar
okay so my car has been filthy the past week with all the rain we've had.so i washed the car yesterday evening. i did a pull today just to humor myself and see if i could get a clearer picture of what was going on. the smoke definatley has a blue tint to it. so i think it is my turbo or oil in the piping. the thing is tho its not constant. the only time smoke comes out of the exhaust is when i'm coming down from full boost. its not consistantly dumping smoke. But coming from say 6K rpm down some smoke comes out the back.
any more advice in this?
Old Jul 20, 2009 | 01:36 AM
Music City Scions
ORLY.......then maybe you should tell that to the people who wrote the directions on the back of my compression tester.
Old Jul 20, 2009 | 02:41 AM
Syldrin's Avatar
i'll cut cha both. you can argue the differences after i stop panicing about my car.
Old Jul 20, 2009 | 04:15 AM
crush02342002's Avatar
talks about the same thing on the back of my tester (and in the instructions) but it doesnt call it a "leak down test"
anyways syldrin you get anything worked on today?
Old Jul 20, 2009 | 11:12 AM
Music City Scions
That's what it's for. To test the rings. They could call it Kibbles and Bits for all I care. It's a test for the rings....not much needs to be said on that.
MrMeanor
Sep 28, 2019 04:37 PM
gqdabien
Sep 17, 2015 09:23 PM
Btp907
Sep 15, 2015 02:54 AM
peruviann
Sep 14, 2015 06:35 AM
