DIY Greddy E-Manage ?
If there is a source for a DIY or explanation on how to install Greddy E-manage can someone please let me know i have an 09 scion tc , would really appreciate it.
1st step buy the plug and play harness.
2nd step take the glove box out (push on both sides)
3rd step unplug the harnesses on the ecu
4th step plug the harness into the ecu
5th step plug the harness into the emanage
6th step take the car to the tuner
i have the wiring harness lol, just woundering if i have to splice any wires or anything ? Also what exactly am i replacing , the stock computer or just connecting it to the stock computer (like a piggy back) ? im new to the whole force induction scene trying to learn as much as possible , i just recieved my turbonetics kit with a greddy emanage, wishing someone was local maybe can help me out installing
Valencia,
Your e-manage is a "piggyback". You'll notice on your wiring harness, there are ports where the stock wiring harness plugs into the plug n' play harness.. then on the plug n' play harness there are plugs that go back into the stock ECU. Do not remove your stock ECU.
It's probably the most complete kit you'll find.
The instructions are near perfect. You really can't go wrong with it.
And no offense - but for you, I would suggest having someone with experience help you.
no offense at all lol , its always good to have someone helping you , looks simple to install though one more question the installation instructions are the same for the all years of the tc ?
So you're getting the T'netics kit with a Greddy eManage?
Make sure also, that you have the correct MAF adapter for your car. I think the T'netics kit for the '05-'06 have a different MAF housing.
so 200+ wires a lil exagerated! lol i hardwired my fic fairly easily and its alot more complicated than the emanage blue lol - fic has direct injector control, o2 sensor, tps, cam pos, crank pos, etc Its not that bad if you have decent electronics and soldering skills - although i did fab my own kit and tune myself so i dunno maybe my definition of not complicated is diff than most :/
props to you tho, i know i'd lose patience after a few wires
