EGTs are high
Old Jul 26, 2006 | 03:02 PM
Streeter's Avatar
My probe is mounted 6" south of where the s-pipe and downpipe meet (like in Kaeon's tech article). Do you think there is a BIG temp drop mounted there rather than up in the exhaust manifold?
My numbers seem to be around 200 or so degrees cooler than what ZEROmotorsports wrote.
Old Jul 26, 2006 | 03:39 PM
ZEROmotorsports's Avatar
the turbo should be absorbing about 200 degrees so yes you are about the same as me.
Old Sep 19, 2006 | 02:06 PM
Streeter's Avatar
Coming back to this again - since I got my s1 installed from ZPI my EGT gauge will occasionally reach 1200 degrees when running hard, and because of the placement of the probe tack on another 200 to get 1400. So is the conclusion we've reached here that there's really no reason to be too concerned about it?
Old Sep 19, 2006 | 02:29 PM
Nick06tC's Avatar
My temps, with the probe in the s pipe 6 inches from the header, reach around 1200 on occasion when its warm out on hard throttle.
But my guage quit working on me. Dont know what the deal is. Its autometer so its a good brand. Maybe a wire loose somewhere.
Old Sep 19, 2006 | 10:49 PM
since I tuned my emanage, the occasional beating will get up to 1400 in the header collector and possibly creep up to 1450 or 1500 during extended.
highway temps are still up there mainly because of the short gearing i think. at 72-75 it sits around 1200-1300
Old Sep 20, 2006 | 12:32 AM
soros151's Avatar
Originally Posted by ScionDad
That's about right......I registered numbers like that as well.
Today I removed the PCV from dumping into the intake manifold and it dropped them all by 100 degrees.
Does anyone knows how is this done?
Old Sep 22, 2006 | 01:18 AM
ERIC-TC's Avatar
Valve cover has (2) ports one goes into the intake upstream of the throttle body the other goes to the intake manifold.
I put a home-made catch-can on my car on the intake manifold side and a breather filter on the front valve-cover port. I guess if the catch-can was large enough it could act like a heat-sink...
There is a topic posted a while back on constructing an exhaust driven vaccum pipe that will suck out valve-cover gases and dump them out the exhaust. Real long and technical - It's a great read.
https://www.scionlife.com/forums/vie...ighlight=catch
and this one
My breather filter looks a lot like the one on this post.
Here is my wal-mart special catch-can...
It's a modified compressed air filter. Works good in keeping oil out of the intake manifold.
Old Sep 22, 2006 | 01:29 AM
WeDriveScions's Avatar
Two questions... at the shop they said I should have the front valve port hooked up to vacuum, but I just have it open at this point... don't see a huge issue there, as no oil ever came out of it with my catch can connected there anyways...
What's the advatage of a catch can in regards to EGTs?
And, for good measure... I'm hooking up my EGT this weekend and wanted to tap straight into the manifold, but don't want to take the whole thing apart.... I'm taking the downpipe off to have my Wideband sensor bung welded in, and figured I could just drill in and add it there....
Add 200 degrees and it's about right? Just wanted to make sure... it'd be a hell of a lot easier.
Old Sep 22, 2006 | 03:50 AM
soros151's Avatar
and this one
I know I saw some where here a how-to on that kind of catch can. Could you tell me where?
Old Sep 28, 2006 | 07:13 PM
toyota_scion_tc's Avatar
Quick question. I am going boost soon so did anyone change their thermostat to a lower temp? From what I read the stock temp is 180 degrees and I know parts stores list a 170 degree wouldn't that help some
Old Sep 28, 2006 | 07:47 PM
Rasta's Avatar
You dont really need to but I did mine is a TRD one I did while after I turboed the car but before I did it was fine I live in Miami and it is hot as hell even when I was idling forever in traffic.
Old Sep 28, 2006 | 07:56 PM
Rasta's Avatar
Oh yea it suposed to run about 140 degrees
Old Sep 28, 2006 | 08:23 PM
ERIC-TC's Avatar
TRD unit is 160F but it list for almost $100. The Autozone has a miller stat 170F model for $11.
I'm ordering the Autozone model tonight...
Old Nov 7, 2006 | 10:20 PM
soros151's Avatar
Do you have the part number? I would like to buy that.
Old Nov 7, 2006 | 10:47 PM
zer0's Avatar
Ditto, I need to go buy plugs anyway. Might as well add this to the list.
Old Nov 8, 2006 | 03:59 AM
ERIC-TC's Avatar
Murray Plus + 3757 cost about $7-8 plus $5 for the special order.
This is a std. 170F stat for Toyoya it fits like 30% of Toyotas models including Camry since like the 90+ and newer. Murray also makes a fail-open model also in 170F.
Old Nov 8, 2006 | 11:05 PM
zer0's Avatar
http://www.importrp.com/product.php?...5&cat=0&page=1
160 Degree Thermostat...hmmm
Old Nov 8, 2006 | 11:17 PM
toyotaracer9's Avatar
hey eric-tc do u notice a difference in where the temp gauge needle sits ?
good find on the 160 temp. thermostat , zero
Old Nov 8, 2006 | 11:19 PM
zer0's Avatar
Yea, Im curious if the 160 will be too cold. Since the TRD has it but the ECU is reflashed as well...
Anybody have this done on a non S/C car?
Old Nov 8, 2006 | 11:27 PM
well if someone has a scan tool they would be able to see when the car goes from open loop to closed loop on the initial warmup . I have one but dont have the software in my g/fs new laptop . might be a good weekend project .
