emanage ignition help
Old Mar 30, 2008 | 01:43 AM
gingles's Avatar
Default emanage ignition help
i hooked up all the emanage wires and loaded the map from it and started the car and came up with ig1 2 and 4 input errors, the emanage flashes red but the car still runs and everything is tuneable. any help would me nice.
Old Mar 30, 2008 | 01:47 AM
java09's Avatar
your jumpers?? are they set correctly?
Old Mar 30, 2008 | 05:30 AM
gingles's Avatar
from what i was told yes....i bought it from another guy on here.....but you make a good point...i think he said he nvr hooked em up...damn...haha...preciate it
Old Mar 30, 2008 | 12:47 PM
gingles's Avatar
bump...anyone else?
Old Mar 31, 2008 | 01:16 AM
Ptuning_tuner's Avatar
Make sure you have the ignition inputs and outputs wired correctly. A lot of people make the mistake of wiring cylinder 1 to channel one, cylinder 2 to channel two, cylinder 3 to channel three, and cylinder 4 to channel four.
You need to have the ignition channels corresponding to the engine firing order. In this case of an inline four engine, it is 1-3-4-2.
So what you need to do is make sure ignition inputs and outputs are wired as follows,
channel 1 - cylinder 1
channel 2 - cylinder 3
channel 3 - cylinder 4
channel 4 - cylinder 2
Yes, the engine will still run the way you have it, but you will get a persistent error code on the e-manage unit (e-blue and e-ult). It may also lead to damage to the unit and/or coils.
Btw, the injectors channels are fine with 1 for 1, 2 for 2, 3 for 3 and 4 for 4. They do not follow the engine firing sequence like the ignition wires do.
Let us know how it goes.
Old Mar 31, 2008 | 04:20 AM
gingles's Avatar
yea i got it...i had the universal harness and it wired up 1234 instead of 1342 but its good now...preciate the help guys
Hydryman
Feb 23, 2016 03:35 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
Krysune
Sep 18, 2015 07:53 PM
skruff
Jun 17, 2015 12:01 PM
