Emanage Ultimate Software Update.
http://www.greddy.com/news/?id=9
e-manage Ultimate ver.2.00
≪ Advanced Capability ≫
Water temperature ignition addition of revision and setting.
Inhalation warm ignition addition of revision and setting.
Data addition of taking MAP.
≪ functional additional ≫
Rotary adding 1/2, 1/3, 1/4 and 1/6 to recognition of the signal.
Engine type Universal (general purpose) addition.
[enjinsutoru] adding water temperature to operation condition of prevention and setting.
Analog adding the pressure indication of the genuine pressure sensor connected time to input.
Correspondence of knocking level indication with logger. <<<<FINALLY!!!!!
I/J adding the fuel pump to relay item inside the tub.
Adding selection possible MAP with the DIP SWITCH of front panel.
Adding the sensor manufacturer of the A/F meter to OPTION1,2 of front panel.
Adding MAP changing performance to the external switch of front panel.
Adding the addition sticking in MAP and the setting picture.
Ultimate adding the automatic 2 division indications of the window and the data logger.
Parameter adding printing the setting.
Adding the logger trace with of cursor B.
Adding the line movement with the left and right button with ・ logger trace.
Adding the rpm every writing out to ・ logger text file writing out function.
≪ functional correction ≫
Setting setting the idea contest to the file and the logger file.
Starting with [double click].
Engine beginning improvement of kinesis.
Acceleration injector modifying the control of revision MAP.
Acceleration modifying the control of ignition and revision MAP.
Acceleration injector mark modification of revision.
Acceleration mark modification of ignition and revision MAP.
Parameter mark modification of setting.
Each MAP, correcting the operation when protect setting it does to setting.
I/J invalid injection mark of time modification and operation correction.
Modifying the printing indication of the logger.
Rotary E/G addition of logger indicatory item when selecting.
carid
Aug 31, 2015 11:17 AM
Subaru86
Jul 31, 2015 04:00 AM
umnitza
Jul 25, 2015 07:54 PM
TheTripleC
Jan 4, 2015 06:46 PM
