FIC Problems and CEL codes
I recently put had the FIC installed and tuned, and now im having a few problems. Its throwing 3 CEL codes.
The first one is P0102: Mass or Volume Air Flow Circuit Low Input - and I have no idea what would cause that. The second is P0172: System too Rick (Bank #1). The third is for inefficient catalyst etc. - and obviously the cat is removed so I'm guessing that one is normal.
But under partial throttle the car stutters alot. And this wasn't happening on the dyno, but now the car stutters under WOT at 6k. On the dyno just a few weeks ago the WOT was perfect. It seems strange to me that its throwing the code for too rich. Wouldn't the code for too lean be more likely under partial throttle? Maybe I should replace the primary 02 sensor? Oh and the tuner did not tune the 02 map - he said he usually doesn't mess with it. But I figured that would make it run LEAN under partial throttle. Should I go back and make him tune the 02 map? Any help would be awesome. Thanks guys.
Yeah I'm not too confident in the tune I'll be honest...
I went to Japtrix and Jack tuned it - Paul I don't know if you remember but we had some issues setting up the software and I called you from the dyno. He had a really old version of the FIC software on his computer so I don't think he tunes very many of them.
And crush - If you would do that for me that would be great. This may be a dumb question but I'm not too sure how to get the map off my FIC. The tuner tuned it on his computer (under an older version I think - for some reason 3.04 would not work). How would I get that map and send it to you?
Even if you could just look at it and tell me what to tell the tuner that would be awesome.
Thanks for the help guys.
crap, first i may have to download an old software version in order for me to view it i think. open fic software on your computer and click on file, click on open, see if you have a base cal or any cal will do. open cal, plug in fic and click on ecu, click on connect, it will come up with a msg saying do you want to down load from fic or to fic. you want to download from fic to computer. this will over write the map you had opened and leave you with the map that is on you fic. put it in your email and send it out.........
crush02342002@yahoo.com
my gosh what is with tuners not filling in the maf and 02 maps...........im really getting tired of seeing this.
do they just not know about them or am i an idiot and dont need them......last part was a joke
what is going on with the tuners these days, they cant be that stupid, i mean they got way more experiance than me tuning but yet they eff up some ish pretty bad.
fuel map looks ok the ignition map looks a little too agressive, no o2 map, no maf map.
ill have to work with it later, gota go to school in a sec.
sorry about the tune though.
ok awesome i got it - i just put a fresh UEGO sensor in so it should be reading accurate a/f ratios and ill keep an eye on everything - thanks again and ill let you know how it runs
if you disconected the battery just before pluging in the fic for the first time with a new tune it could be normal. the ecu needs to adjust and relearn. while your at it make sure your running the proper software and flashes (just to make sure ya know). I still have a copy of the map so ill triple check it.
btw once you have disconected the batt and reconnected with a new tune it could take up to 20min-30min of easy driving to get everything to settle. if its running rich then thats ok but if it stays consistantly lean in idle or easy driving then we got problems.
ok so i should disconnect the battery and drive it easy for a little while? btw - i saw on the aem power forums that you should leave the MAF FUEL map all zero's - and mine are definitely not. should i change them to all zeros? its kinda easy to miss if you dont look for it - see what your map looks like its the little tiny icon in the upper right hand corner of the MAP fuel map
