First Dyno Run For Jet Blue :-)
Old Mar 12, 2011 | 12:57 AM
Rasta's Avatar
Default First Dyno Run For Jet Blue :-)
Sup Fellas
So I went to the dyno today after weeks of trying to get the car to drive like stock and it does. It drives just like OEM, idles hard core but what are u gonna do. Cams, 120lbs injectors (I came down from 160lbs couldn’t get it to idle consistently) and I put one solid mount the rear one and man what a difference in drivability. Anyway so we did a mild tune didn’t really touch the timing much just some gas and boost and it made 440whp at 18psi. I know we could get more out of that boost but we took it easy. Next time I go I’m going to push the boost up to about 25psi. The car should make well over 550whp.
It made 366whp at 13psi so it picked up 70hp when we went to 18psi. One thing for sure the car feels CRAZY! One question though what the hell can we do about tire spin its ridiculous! I’m thinking of putting some led sacks in the front. What have you guys done?
Old Mar 12, 2011 | 01:00 AM
weezyfbayba's Avatar
what cams do u have? im having problems getting mine to idle below 1700 rpms it will just stall out i have bc stage 2 and descendent intake mani also
Old Mar 12, 2011 | 01:03 AM
Rasta's Avatar
Same ones
Old Mar 12, 2011 | 02:25 AM
brett561tc's Avatar
dayyum son!
Old Mar 12, 2011 | 02:45 AM
Ace83's Avatar
Ronin Scion
E85 right, hydra ems? tires spins, i guess you would have to put 275 sticky tires w/ really stiff suspension lol.. good numbers, but yeah 25 psi! lets see
Old Mar 12, 2011 | 03:38 AM
m6ar2cel6oTC's Avatar
Welcome to the 400 club! Why didn't you just go str8 to 25psi? Either way nice as numbers.I also went to the dyno last Saturday. I wanted over 500 but my nice 875 didn't want timing lol. You should he running mmore timing since you have e85 and you probably close to 500 with that same Psi. Did you ever port that TB?
Old Mar 12, 2011 | 10:43 AM
Rasta's Avatar
Just taking it slow bro no need to blow my wad too quick :-). I will do it soon I want to try and deal with the tire spin first. All that HP with no hook is useless. I did port the TB and I put it on but the idle was too high so we took it off. We are going to try an adjust the buterfly to help close the gap from the port.
Old Mar 12, 2011 | 11:42 AM
crush02342002's Avatar
nice!!..congrats on the power!
Old Mar 12, 2011 | 01:38 PM
brett561tc's Avatar
just out of curiosity, whats going on with the afr's on the garph? they look scary lean at peak tq.
Old Mar 12, 2011 | 01:42 PM
mmmpshh's Avatar
very nice!
Old Mar 12, 2011 | 02:53 PM
Rasta's Avatar
E85 you can run a little leaner..my tuner did clean it up though after that run.
Old Mar 12, 2011 | 03:01 PM
brett561tc's Avatar
oh, ok. is the dyno using a special o2 sensor for e-85? i thought e-85 was supposed to be in the 9's for afr.
Old Mar 12, 2011 | 03:25 PM
Rasta's Avatar
9's! that thing would be bogging out with all that gas. You use the same AFR sensor that you use with pump, you also tune it the same. There are alot of myths out there about E85. You can however run a little leaner, it does not knock as easy.
Old Mar 12, 2011 | 08:52 PM
i say run normal afr but with a lil more aggressive timing and you still would be safe. that e85 is like liquid gold around here lol
Old Mar 12, 2011 | 10:06 PM
mmmpshh's Avatar
E85 is the magic juice!!!
Old Mar 14, 2011 | 12:41 PM
Rasta's Avatar
Fo Sho!!
Old Mar 14, 2011 | 01:55 PM
sci0n-tc's Avatar
Nice, Can't wait to see it at 25psi
Old Mar 14, 2011 | 03:22 PM
thendawg's Avatar
The 02 sensor doesnt know the difference between e85/pump gas - all the wideband does it measure difference from stoich (aka lambda). The afr value you see is simply lambda x stoich value. E85 stoich is like 9.7:1, so in reality most of us really are running somewhere in the 7 or 8:1 range during wot. However, most people just leave the wideband setup for pump gas (14.7:1 stoich), so the afr numbers you see, are simply based on a pump gas scale. Some people will just change the wideband to read lambda directly (no afr calculation) and tune based on that. Personally I perfer using the gas scale.
Old Mar 14, 2011 | 04:44 PM
ElevationTC's Avatar
Run file 32... It took 32 pulls to get there and you didint touch timing much?
Looks nice a smooth though.. Glad you got all the idle issues figured out. Its nice to have fast car, but if it dont drive smooth then its not fun!
I used to spin all 5 gears with 255-35-18s. I had ____ty suspension which did not help me.
Raise rear suspension some. run some stickies in front. 0 out the camber LSD. And then still deal with the fact you have 400+ fwd =D
Enjoy nice car, nice setup!
Old Mar 15, 2011 | 01:39 AM
Rasta's Avatar
Nice good advice..I didnt do near 32 pulls that for sure, about 10 maybe. We did a low and high boost setting. Damn so you tore up the 255 too huh. Did it at least pull while it spun
my06tc
Jun 25, 2015 12:18 AM
hotroddelux
Dec 3, 2014 11:33 PM
Scionic
199
Jan 8, 2006 11:09 AM
arinvolvo
Jan 21, 2004 11:40 PM
Besk_one
10
Dec 6, 2003 06:45 PM
