garrett turbo noob q
i saw someone selling a garrett 60/48 turbo....now im not purchasing it but my friend is and he asked me what the 60/48 is and i didnt know exactly....what is it? THANKS
no seriously, i searched but there is nothing that says that; ive seen one site but i couldnt find information the person just typed that; ive found garrett 48/60 and garrett 60 & garrett 48; but this guy is selling him one turbo it clearly states Garrett 60/48 turbo (no shaft play) and what does the shaft play mean? THANKS
after doing some digging this is all i've come up with.
http://cheapturbo.stores.yahoo.net/gat3w48ar.html
wow that may be it, i dont know....thanks alot...and thanks for explaining shaft play....well thats a good thing there is no shaft play....so is there any turbos that DO have shaft play, if its bad why do they have it?
you've been really helpful...but the turbo is for a integra; thanks alot....but one last thing....what does the numbers mean and what does that mean....
i.e. 60 means 60mm whatever
60mm whatever means....it will move 60mm
sorry for the trouble im planning to boost my car and since my friend is getting it; i might be able to pick up some tips and terminology before hand;
thanks again!!!
thanks again!!!
Originally Posted by Syldrin
they're old and worn. and a 60-1 is WAY to big for a TC. you wouldn't get boost till like 9th gear with a 60-1
well first of all thats the turbo i have. secondly, people swear up and down that you need a turbo that reaches full boost at 3k rpm. this is BS. i had a zpi stage 1 kit, and yes it did spool very fast. so fast that i could not get my tires to catch untill late in 3rd gear. with a small turbo you do make alot of low end torque, but not as much top end hp. with a bigger turbo its reversed. you make more power up top. those that race there turbo tc's can tell you. once you launch you take your car to redline at 6250. then you shift to second. your rpm should not drop below 4500, if you can properly shift. then you shift into third. still your rpm should stay high...
i dont know about you but i would want my turbo to have its powerband in the rpm range that i stay in all the way down the track.
i dunno what AR means. but it's the A/R.
a Gt3071 is a good turbo for a 4cylinder. or smaller
