Greddy Emanage Ultimate Limp Mode
#41
all i have to say its the TUNE!! i had this problem with a tuner that swore up and down that he can tune tc's! then i went to another tuner that was reccomended and WALlA! i'm rich anymore between 4-4500 rpms and my car doesnt tall anymore!! its all about the tune. and as far as ultimate only tuning partial throttle WRONG! you can tune it. you just have to have the fuel trims close between the ecu and the ultimate from what i was told. anyways if i were you try a different tune that has tuned tc's successfully.
#44
ok i understand i checked for leaks and everything and I found nothing, the management had a tune on it for my kit off of another car , i smelled gas when we first installed it. Can running rich mess up the tune ? Regardless i think my tune got messed up.
#46
Originally Posted by brett561tc
the solution for the common piggyback...
http://www.dezod.com/pd_dezod_motors...standalone.cfm
Hydra > AEM
#47
Hydra > AEM
You would have to multiply yourself by 10 to equate to me son....
#48
Hydra > AEM
BAZING!!!!
#49
Originally Posted by m6ar2cel6oTC
your tune didnt get messed up! your ecu realized you had a piggyback thats all. cause your tune!!!! no it wont mess your car it will mess up your spark plugs.
#50
#53
Originally Posted by UNiT_xEr0
Tune yourself
#54
Tune yourself
#57
car is back to normal. no more black smoke. the reason why it went into LIMP MODE was cause of the volt on the o2 sensor. so talk to you tuner and tell them to play around with it. what happened to mine was that it was letting out 50% fuel causing the stock ECU overriding the piggyback. and if your turbo'd and running a piggyback in SoCal make sure you bring it to shawn at churches cause he can fix partial throttle. its awesome!
#58
^ thats good to hear that eveythings going good.
I figured out my problem my wastegate was stuck open therefore the pressure was escaping and not boosting. Heres a picture guys. by the way my tune is fine it was a mechanical problem. The wastegate is running fine for now but im in for a new one TIAL baby!!
#60
Hydra > AEM
BAZING!!!!
When was the last time you posted something about your car hitting the track, driving down the street, or perhaps moving out of the driveway?
BAZING!!! LOL....
Anyhow....dodaddy, what ended up being your fix for your problem?
