header w/ trd sc
Old Sep 22, 2007 | 09:33 PM
KiKaZ-tC's Avatar
Default header w/ trd sc
I've been wanting to install headers for quite some time, but dread the idea of having to remove my s/c... do I really have to remove the s/c to install headers?
Old Sep 22, 2007 | 10:06 PM
tikbhoy's Avatar
Default Re: header w/ trd sc
no, the only hard part is removing the stock s/c heat shield. you just have to maneuver it around.
make sure you have a angled socket that can fit to tighten the left header nut.
buy new gasket, dont risk using old gasket and get a leak later
Old Sep 22, 2007 | 10:10 PM
KiKaZ-tC's Avatar
thank you for clarifying things for me!
Old Sep 22, 2007 | 10:14 PM
Kydog's Avatar
Nick ... sup man been a while already.
You already have the header or your just asking before you buy one?
Hit me up dude.
Old Sep 22, 2007 | 10:20 PM
KiKaZ-tC's Avatar
I don't have the header yet, but I definitely plan on going full exhaust asap now that I know I won't have the remove the s/c, thank goodness!
Kyle... turbo? huh huh? come on, please... I want a ride!
Old Sep 23, 2007 | 12:46 AM
jwaggz82's Avatar
You dont have to remove it but you might have to bend the shield down a VERy little bit to get it to pass under the shaft. I installed my header w/ the s/c on so it surely is something that can be done. To get extra space to work you can remove your radiator fans ...that will give you more room to work with
Old Sep 23, 2007 | 01:02 AM
KiKaZ-tC's Avatar
good info... thanks!
Old Sep 23, 2007 | 01:33 AM
Kydog's Avatar
Well let me know when you pick up the header... ill help you install or we can install in my garage.
Also if you want to pick up that catback i told you about in downey ill roll with you. 230 cash picked up i think full s pipe back deletes the cat.
Turbo.... you know it!!! I need to get my finances straight first though...
Old Sep 23, 2007 | 11:12 AM
TongMan's Avatar
It's a pain in the ***** to work around the Supercharger shaft. The bottom left nut will be the hardest nut to get off once you get the heat shield off. You don't have to take any part of the supercharger off, you can work around it. I did it with normal tools in my garage.
Old Sep 23, 2007 | 12:16 PM
jwaggz82's Avatar
We used a socket piece that allows the socket extender to be bent ...so it wasnt bad at all.
Old Sep 23, 2007 | 03:09 PM
tikbhoy's Avatar
it will also make it super easy if you remove your o2 sensor first.
you can buy the socket at kragen, it specially built for removal of o2 sensor.
Old Sep 23, 2007 | 03:15 PM
tikbhoy's Avatar
you shouldnt remove the radiator fans unless you dont remove the o2 sensor first. it just give you more room to wiggle the heat shield.
try your best not to trash the trd supplied shield
Old Sep 28, 2007 | 06:20 AM
KiKaZ-tC's Avatar
Thanks guys! I got my alphawerks header which I got for $150 used from ebay/scion life member today and had it installed today! I am kind of worried that i didn't get it ceramic coated, but I believe there are several s/c owners that run header with no type of heat guard.
Anyways, it was PITA! As I'm sure all of you expected.
I have to thank Kydog for giving his time to install/help get my headers on; lol, more like Kydog installed it. But I tried to put in my work here and there! He had to drive me to autozone three times for us to find something that would fit between the DREADED left bolt and the alternator! I swear... the whole time I was thinking how easy this would be if the s.c. wasn't there, while Kydog sat there with a migraine all day (sorry buddy!). Anyhow, it took us quite a while.. but we did manage to get the header installed without removing the supercharger, so once again I thank those who informed me it wasn't necessary to remove the s/c to install headers.
As for the performance, I'm not too sure if Kydog was impressed with the header upgrade considering he's a former heavily modded WRX owner, but I could definitely notice the difference! Seem like all around the car is much smoother and I definitely have more high end power.
I'm happy with the results. Now for the catback...
Old Sep 28, 2007 | 06:08 PM
Kydog's Avatar
LoL thanks for the shoutout Nick... you want to give them my social security number also???
Im glad you like it and trusted me with your car. Im waiting until you get that nst pulley than i need a ride again! As for now go drive around and enjoy the sound of your Vtec
Old Sep 28, 2007 | 09:57 PM
KiKaZ-tC's Avatar
Vtec?
5N1PE5
Aug 3, 2015 11:25 AM
ack154
47
Jan 31, 2010 12:27 PM
400amonth
Sep 6, 2005 07:11 PM
Rimjay
16
Jul 7, 2005 07:08 PM
