help.. diy aem wideband
Run the cable harness for the sensor through the rubber grommet in the firewall on the drivers side. The power harness has 4 wires. Red, black, blue and white. The Red is for your 12v power, black ground, blue datalink, and white is a narrowband output. Wire accordingly. You will not need to wire the blue or white wires unless you run a standalone ems. Put a switch on the ground, or contact Joe_Dezod and he can help you with a relay circuit. I spliced the power into the aux power outlet in the center console.
/\/\ otherwise the sensor/gauge will ALWAYS be on. Plus the install guide says to wire the power wire to a 12v "Switched" 10amp source. However you can switch either side you want, +/-
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
