Help needed urgent!
ok well everything was running fine with my blow-thru maf setup now im starting to get "system too rich" codes after like 6 miles of driving,
my injectors are 410cc trd
also if im on the higway and im at 4k rpms my car goes straight to a 10.0 air fuel ration if not richer, for me to correct this i have to let off the gas for a couple secs and then get back on it(mind you i dont have any partial throttle adjustments...)
also after doing a pull if i go into the next gear and try to cruise on the throttle my a/f are 10.0 again....
i keep resetting the ecu!!!
possible reasons?
its colder out and because of the the air the maf is reading is 37 degrees and is tryna dump fuel to compensate for cool/dense air?
something effed?
tomorrow i have a long drive 2-2.5 hrs to Maryland international raceway just for the show i wont be racing...
so before i go ima try to switch back to draw through and see whats up
possible reasons?
something effed?
something effed?
Good luck and have fun tommorrow.
problem solved i just simply set my SAFC to subtract 15% fuel form 4200 to redline during partial throttle and this is good i have it at 13.5 a/f ratio and i think thats a good ratio right?
my06tc
Jun 25, 2015 12:18 AM
rancur3p1c
Dec 19, 2014 04:30 PM
