help random misfire
Old Sep 8, 2012 | 05:05 PM
speedintc's Avatar
Default help random misfire
i just recently got my head rebuilt after bending a valve back in march, but long story short i got the car all back together it has low compression wiseco pistons, sleeved, built head and a fuel return setup. the car runs fine but today i had it sitting at idle and i noticed it kept wanting to die and so i got in it and it was flashing the cel like for a misfire. anyone who what could cause suck a thing?
Old Sep 9, 2012 | 02:25 PM
BlackKnight's Avatar
Music City Scions
The tune or fuel system, what engine management are you running, also what fuel injectors are you running?
Sent from my Galaxy Nexus using Tapatalk 2
Old Sep 9, 2012 | 04:47 PM
speedintc's Avatar
o yea i forgot to mention that im back on stock management and stock injectors
Old Sep 9, 2012 | 10:17 PM
trd07tc's Avatar
Did you perform a compression and leakdown test?
Old Sep 9, 2012 | 10:25 PM
Music City Scions
What's the AFR? Also do a compression test dry then wet compare the numbers to make sure your engine is ok like the last post says.
Old Sep 10, 2012 | 08:20 PM
speedintc's Avatar
afr's are on the leaner side at idle but i think it may be because i have an exhaust leak. my s-pipe was modified to fit my down pipe so its a little bit off to the stock header. im still trying to source a stock s pipe or just get a flex s ection added to mine
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Prolific998
Scion tC 1G ICE & Interior
Apr 16, 2017 06:09 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
mcnick0495
Scion tC 2G ICE & Interior
Sep 8, 2015 02:58 PM
JoggerFogger
Photography & Video
Jul 27, 2015 09:34 PM
