Hodge Podge: Houston style
Old Dec 17, 2008 | 10:34 PM
  #981
crush02342002's Avatar
well i went to the dyno last week
292hp
278tq
Old Dec 17, 2008 | 11:01 PM
  #982
java09's Avatar
nice!!!!!!!!!!!!!!
Old Dec 17, 2008 | 11:57 PM
  #983
Ace83's Avatar
Ronin Scion
nice! self tune, .83 a/r ftw!
Old Dec 18, 2008 | 12:52 AM
  #984
its ok for what it is.......but i expect more to come.
ace i think its 82a/r.........crap now i gata check
Old Dec 18, 2008 | 12:55 AM
  #985
yep 82....lol
Old Dec 18, 2008 | 01:26 AM
  #986
ok i got a few questions for you guys.......now keep in mind this isn't an immediate thing I'm working on but id like to get some point of views on a possible engine build........ill start with a spare 2azfe sourced from a junk yard. Measurements will be taken while tearing the engine down to find any problem parts. So the first problem i'm going to run into is I don't have the complete specs of a stock engine. I need something to reference to, so if you guys could guide me to them it would be a big help.
second (please forgive me if this sounds noobish) I am toying with the idea of either stroking it or desroking it. i know how it works and the major parts for both but iv never done it.
hears the idea i have for both
stroker-
stroker kit, thick head gasket (idk how thick i can use nor what is available just yet...more research will be done), low compression pistons. prolly run it on 11-12psi of boost (just a short list so you can get the idea)
destroke-
sourced crank and con rods from another engine of maybe something from the toyota family,high compression pistons, on 20-25psi boost
of course either way the block would be sleeved, stronger head bolts, pnp heads (prolly from dezod), bc stage 2 cams, standalone ems, ect.
iv done rebuilds only so this is a new front for me, any helpful ideas would be great.
Old Dec 18, 2008 | 05:49 PM
  #987
TurboToyotas's Avatar
Chris-
few questions?
why stroke it? the benefits of stoking vs the cost of doing so is not that great, and the money saved by not stoking it will be well spent elsewhere and the benefit much more rewarding.
why destoke it? rev high sounds cool and as with stoking has its benefits if your building a car for a specific purpose(ie powerband dictated by gearbox limitations etc for a roadrace car, rules etc)
Now if you just want to do either or both for the heck of it...sweet. You will learn allot and the community would benefit from it greatly as you are willing to share your experience with all of us.
But if you are trying to build a good sound motor for your setup(future setup) there are better options than you mentioned. Ones that will have greater return on investment.
Regards-
Todd
Old Dec 18, 2008 | 05:56 PM
  #988
Chris-
few questions?
why stroke it? the benefits of stroking vs the cost of doing so is not that great, and the money saved by not stoking it will be well spent elsewhere and the benefit much more rewarding.
why destroke it? reving high sounds cool and as with stroking has its benefits if your building a car for a specific purpose(ie powerband dictated by gearbox limitations etc for a roadrace car, rules etc)
Regards-
Todd
Old Dec 18, 2008 | 06:18 PM
  #989
java09's Avatar
the TODD has spoken.. hahaha
Old Dec 18, 2008 | 09:40 PM
  #990
well my goal it to transform my car into a drag car. starting with some of the basics and moving closer to a complete drag car.....i heard of someone stroking the 2az with some pretty good success. I kinda thought that for my app something drastic like stroking or destroking would benefit me greatly. I now see the light...lol
The first time i went to the drag strip i instantly feel in love with the motorsport, its straight up addicting.
thanks Todd and holler back at me....id like to get some sort of plan togather.
Old Dec 18, 2008 | 10:42 PM
  #991
Ace83's Avatar
Ronin Scion
interesting idea chris!
Old Dec 18, 2008 | 10:46 PM
  #992
CarbonXe's Avatar
What kind of dyno was it? Chart plz . I want to see how my base tune did for ya lol.
Old Dec 18, 2008 | 10:50 PM
  #993
i didnt dyno on your tune.....sorry your tune took a dump on me the first day i was to run my car at the drag strip so i had to scramble to make something work.......i loaded up phils map and used the top portion of your fuel map. I also had to flash my fic with z104.hex. ill post up the sheets in a few.
Old Dec 18, 2008 | 10:51 PM
  #994
oh yeah it was a dyna pack
Old Dec 18, 2008 | 10:54 PM
  #995
CarbonXe's Avatar
Ok, no clue how those compare to DynoDynamics lol.
Old Dec 18, 2008 | 11:00 PM
  #996
well i think my #s would be lower on a dyno dynamics.
Old Dec 18, 2008 | 11:02 PM
  #997
CarbonXe's Avatar
Apparently they read lower than a DynoJet, but not as low as DD. With the bigger turbo, you should be making more than me in the top end. Then again, I'm running a full 3" exhaust.
Old Dec 18, 2008 | 11:22 PM
  #998
i had my qtp open so idk its the exhoust.......i noticed that your tune isnt hardly pulling any timing...this tune im on pulls an arsload of timing........1degree per psi of boost is about what its doing...........i think ima add some timing in.
Old Dec 18, 2008 | 11:35 PM
  #999
CarbonXe's Avatar
I'm pulling roughly .75 degree per pound.
Old Dec 18, 2008 | 11:41 PM
  #1000
the map i have of yours isnt pulling timing till like 4psi i think........ill have to look again......ima bout to work on my map.......
oh just scaned my dyno sheet ill post it in a sec.......gata load it to photo bucket first.
