How Much WHP? (S/C)
How much WHP are you guys pushing with the superchargers that have Blow off valves? I heard that there is a gain in power as opposed to getting a BPV, so I wanted to see how great of a power loss we are talking about.
Originally Posted by lil_will
Wow, that was uncalled for.
Originally Posted by kikcaffine
thats not what I originally posted....... it was alot meaner with more flips and the such in it. Im a changed man! *GASP*
Im not sure who told you that but with the s/c setup you only want a bpv so your sensor can read the air correctly. We have gone over this 101 times and its proven that if you love the bov sound you can do a 50/50 bpv/bov and get it regulated so it blows off like 30% but thats just so you can have cool points. But - for your cars sake .... only put a bpv so the ecu doesnt flip out
Getting a bov with a rec fitting would deffinitly be in your best interest, I went from the bosch 110 bpv to a 50/50 hybrid. The bov held the boost much better than the bosch bpv did, a hks ssqv with a rec fitting is a good option also.
i got my gofastbits hybrid from someone on here and i just put it in without adjusting since it came of another tc and worked just fine closed when touched the pedal and released when i let off the pedal and never ha d aproblem? except when i dynoed m car i got 207 whp with 9.5 pulley so i might try to lower that to what jswagg said to 30% see if that helps anything? actually i got a question of my own how would you know that you have 30% going to the atmosphere and the rest back to the intake! cause i wanna do that!!!
^ you will have to go by sound. Redline it in 2nd gear and let off 100% instead of switching gears into 3rd. Listen to how much blows off. Also - You can open it all the way and count the turns back - then open it back 1/2 the amount of turns. If its 10 turns then you know you would want to open it 3 times.
Try with that kind of logic and let me know. Ide try to get it open 1/2 way then listen to the blow off so you can get that that 1/3rd open mark
