How to turn up boost on the superchargers?
Besides switching out the pulleys is there a way to turn up boost on the supercharger? Now the hp i know header and exhaust and stuff but the sc it self is there a way to get the boost up, people are saying how the sc is capable of 19 psi boost, thats cool but how do you access it?
Ic and a turbo is pretty much just limited to turbos possibility, hm k then the next question is how high can you run the boost on the trd sc, as in is it possible to make pulleys small enough/lite enough to run higher then 10 psi boost? if not, then is it possible to achieve 300 whp with the sc as fi or do you need to go turbo?
Supposedly the vortech blower is good for 19psi (roughly 450hp). Obviously you'd need to build up the internals & tune it to handle that kind of boost, but it is possible with the trd setup.
Team No Limitz
yea, truthfully, the only way to get more psi out of this blower is gonna be w/ an extremely oversized crank pulley and a tiny a$$ blower pulley...its not like a turbo where you can just hook up a boost controller and crank it up to whatever you desire. Im happy w/ the performance right now w/ the supercharger, its not a fast car but its quick...Im gonna do the boost pulley and see how I feel about it until Munch starts beating me up about gettin the crank pulley also
1/8" off the radius or diameter?
i heard something similar, 10mm for approx 2 maybe 2.5 psi.
I take that increasing the drive pulley or decreasing the sc pulley by the same amount would have the same effect??
ie increase drive by 10mm dia = +2 psi
is the same as
decrease sc pulley by 10mm dia = +2psi
is the same as
would that be simplifiedscion by any chance? cos i cant find the other member?
https://www.scionlife.com/profile/SimplifiedScion
yes, yes it is its murder trying to search thru the memberslist!
anyways, what advice can you give on the diameter of the pulley Vs boost increase etc etc on the following statement
is the same as
is the same as
Team No Limitz
is the same as
is the same as
clickclickw00t
02-18-2015 08:57 PM
TheTripleC
01-04-2015 06:46 PM
spawnconnery
12-18-2014 08:38 PM
