I might have a compression issue
Old Nov 20, 2010 | 05:02 PM
AZGuy's Avatar
Default I might have a compression issue
I have never dealt with kind of an issue before, would like some input into how bad I may be off.
Had an odd chain of events happen and will tell so you have the whole story, first noticed puffs of smoke coming from the vent in my kami hood this week. Thought as first I had just gotten some blow by and it was burning off but it continued. Car started to run funny, little putt, putt, putt at idle.
So decided to check things out today and decided to run a compression test and before I could run it found part of the rubber boot from the spark plug socket had been left in on the spark plug. Looked like it may have still been making contact so not sure there.
So did the compression test all but one cylinder was in the 160 range including the one with the goofy rubber left behind. One would not read over 120 and I disconnected, reconnected and ran a few times still the same.
All that said, how bad of shape am I in?
Old Nov 20, 2010 | 06:45 PM
thendawg's Avatar
Prob trashed ring landings in that cylinder. Seems to be a common failure on boosted tc's.
Old Nov 20, 2010 | 07:56 PM
crush02342002's Avatar
^^ agree
youv got a bad piston or a valve problem. Im willing to bet broken ring landing.
Old Nov 20, 2010 | 10:22 PM
Syldrin's Avatar
if it makes you feel better my car reads 160 on all cylinders and 180 on #3
Old Nov 21, 2010 | 12:06 AM
OuterHeaven's Avatar
and I thought I was bad... 140,142,140, and 148. This is an 05 motor obviously.
Old Nov 21, 2010 | 07:32 AM
a-mendoza's Avatar
Originally Posted by crush02342002
^^ agree
x2
This is what lead to my whole build. If it wasnt for this i would still be rockin a stock motor on an S1 turbo kit.
Old Nov 21, 2010 | 04:05 PM
brett561tc's Avatar
how much vac are you pulling at idle?
Old Nov 21, 2010 | 05:08 PM
^^good question
Old Nov 21, 2010 | 08:39 PM
AZGuy's Avatar
I am pulling about 20 inhg at idle, not sure if that is good or bad. I have know something was off on the engine but hadn't been to pin it down.
Old Nov 21, 2010 | 10:03 PM
20 isnt too bad...hmmmm
Old Nov 22, 2010 | 02:18 AM
AZGuy's Avatar
It is 20 at best, it does occasionally flutter just as I give it throttle. Also forgot to mention that I was geting a decent amount of smoke out the dip stick tube while it was running when I took out the dip stick.
Old Nov 22, 2010 | 03:59 AM
its going to change with throttle input, at idle idealy you want 22inhg (after car warms up and at idle), 20 isnt too bad for idle but could be a sign of ring wear or just a vac leak. or valve.
Old Nov 22, 2010 | 05:40 AM
AZGuy's Avatar
I wouldn't think vac leak since I check that pretty regularly. We will see this week how bad it is.
Old Nov 22, 2010 | 08:01 AM
I just threw that out there as a possibility of lower than norm vac reading.
Old Nov 22, 2010 | 06:31 PM
SoccerBoy_AP's Avatar
When I saw little puffs of white smoke from my vented hood it turned out to be the S/C seal going. Never effected performance but I took it to the dealer the same day.
Old Nov 22, 2010 | 07:08 PM
AZGuy's Avatar
This issue started pre me rebuilding my supercharger, my SC is now completely rebuilt and running smooth.
Crush didn't mean to come off odd, I welcome any suggestions, why I posted.
Old Nov 22, 2010 | 07:53 PM
BMXTurbo's Avatar
Im at 17 at idle I have a vac leak?
Old Nov 22, 2010 | 11:27 PM
i didnt take it wrong, i got ya
Old Nov 22, 2010 | 11:32 PM
its possible...i dont know your setup but it sounds like a vac leak
http://www.youtube.com/watch?v=uixdw49Km4s
Old Nov 23, 2010 | 01:14 AM
BMXTurbo's Avatar
Thanks for the video! Im going to have to check for vac leaks. Car runs good and idles like stock though. Its an autometer boost gauge maybe Its not working right.
