i'm getting a new s/c charger
http://cgi.ebay.com/ebaymotors/New-C...Q5fAccessories
In this item, is just the Supercharger.
We can supply you with a Bracket (valued at $160), Cooler (valued at $310)
and crank pulley (Valued anywhere from $330 to $440) to mount to your car.
All units come complete and ready to mount.
Comes withs 3 Months warranty. 12 month total warranty for an extra $100.00
Hits 26 PSI
No Gears = Less Weight = Less Gravitational Pull = Less Wear
No Hsp loss Due To Gearbox
No Gearbox
No Gear Noise
5mm Pitch Teeth Not 8mm Wide Creating Larger Ratio
No Oil
No Oil Means No Contamination
No Oil Leaks
No Oil Evaporation
Poly Housing Stays Much Cooler Than Alloy Housings
Poly Housings is Roughly 1/3 Lighter Than Alloy Housings
Supercharger Has One Shaft Not Two
It Contains The Shortest Shaft In The World
Short Shaft Creates Bearings To Be Located Closer Together Creating More Support
No Huge Price Mark Up
Smallest Supercharger In The World
The Only Supercharger Supported At Both Sides Of The Pulley
Bad Boys Superchargers Can Vary Boost Without Buying A New System
Suits Any Vehicle
Balanced Six Times Higher Than Most Superchargers
Bearings Require No Oil
One Of The Lightest In The World
First Clear Supercharger In The World
First Custom Housing (Colours, Lights Etc)
Fits Jet skies, Boats, Trucks Etc
Aero Dynamic Nuts
Steel Plates, Not Alloy. No Bearing Slip
Dollar Verses Horsepower
can some body tell me is this is a worth while buy
Hits 26 PSI
No Gearbox
No Gear Noise
No Oil
No Oil Leaks
No Oil Evaporation
Suits Any Vehicle
Aero Dynamic Nuts
Greg S
Jul 21, 2016 07:28 PM
carid
Dec 4, 2014 09:35 AM
