The infamous ring question
Old Jun 10, 2012 | 01:55 AM
TimmerTC's Avatar
Originally Posted by PeArLwHiTe07tC
I doubt valve seals too. That ull notice more during start up. I have a similar issue goin on right now from running the car too rich under boost. Im gonna try tossin a catch can in and pray for the best. Keep me posted w ur find bud and ill do the same.
Well I'm pulling the head tomorrow and Ill see if it's just the rings or the landings.
Old Jun 20, 2012 | 05:44 PM
Paradynos's Avatar
any update on this?
Old Jun 22, 2012 | 12:57 PM
TimmerTC's Avatar
Originally Posted by Paradynos
any update on this?
Yeah! cylinder walls are fine, unfortunately I guess on the little drive home the turbo must have been starved of oil cs the bearings are shot. I just had a brand new garret cartridge put in for $450 ugh. I'll be selling all my stuff soon enough and throwing a set of those 2azfxe pistons in and selling the car soon.
Old Jun 24, 2012 | 07:04 AM
ScionFred's Avatar
Wow! Bad bearings and seals on a chinacharger... hard to believe.
Old Jun 25, 2012 | 03:25 PM
TimmerTC's Avatar
It was all garret, the only thing left of the chinacharger was the exhaust and compressor housing the cartridge was replaced. In other bad news my brother in law said he could set the motor to tdc for me while I went to work. Needles to say he took the timing cover and off turned the motor over a bunch of times. So because the timing cover was off the cams turned as a result, long story short he bent every valve in the head and snapped one off. he called me and told me that the motor didn't want to turn over any more , which means all the valve guides are probably screwed. I may need a new head ugh, well I guess that's what I get for letting someone else handle my mess.
Old Jul 3, 2012 | 11:16 PM
DeAnzaJig's Avatar
When you did the Compression test, was it at operating temperature? and What tester did you use?
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
