Injectors question
Anybody have the dimensions of our OEM or even aftermarket injectors. I'm putting together a custom turbo setup, and my buddy has a set of spare injectors that he didn't use in his turboed tiburon. He believes they could possibly fit, but we'd like to know the dimensions of those in the tc. If someone has a set lying around, maybe you could take some measurments. Height, each different circumfence over the length of the injector, etc. Thanks in advance for any help.
you don't have a tC yet to put this custom turbo setup on? If you do, you should just pull them out and measure them...if not, why are u making a turbo kit without something to design it around?
OMG, dude, seriously! do not, i repeat DO NOT borrow injectors make for another car and use them on your tc turbo project.
i think it was 8psixa who had a turbo toyota's kit on his xa, he modified injectors from an acura tsx to fit on his xa. and well...this is what happened
https://www.scionlife.com/forums/vie...020&highlight=
you can get a set of plug and play injectors for 340 from dezod
http://www.dezod.com/pd_deatsch.cfm
otherwise your tc might become extra crispy.
Team No Limitz
no, i'm not turbo'ed, but seriously, why risk your whole ride on modified injectors or injectors from another car when you can by a great set of plug and play injectors made to fit perfectly in our cars.
if you have a car that doesn't have alot of aftermarket support, you have to improvise and modify parts to make them fit and work.
but when you have a scion tc, there are lots of quality off the shelf made to fit like a glove parts.
and your boosted, you should be familiar with the phrase, don't boost on a budget. so why cheap out on injectors?
Team No Limitz
well, i'm pretty sure those acura tsx injectors were oem quality, but that didn't work out very well.
either spend money on getting the right injectors, or spend a couple thousand on a new car when it catches on fire. i'd gladly spend 340 on some rc injectors, then take a free set that take some convinving to make them fit.
Team No Limitz
I have a tc, and after having spent nearly 3 grand on quality parts the injectors are the last thing I need. I am aware of all the options I have, but I just want to know if these 'free' accel 550 cc high impedence injectors will fit.
bootlgr
Jan 26, 2016 01:22 AM
