A little disappointed with the TC engine..
Old Aug 18, 2006 | 11:47 PM
  #41
MountScion1's Avatar
but even at 300 whp, pistons and rods are all that are really needed? Nothing else would really be neceassary? If I do make the decision to go FI, I'd rather error on the side of caution, than potentially get stuck with problems down the road. Thanks for any input
Old Aug 19, 2006 | 12:13 AM
  #42
Prototype_xB's Avatar
Default Re: A little disappointed with the TC engine..
Originally Posted by Rasta
Anyway what I am getting at is when I was dynoing my car they had a Integra with a K20 engine same as the civic SI stock internals it just had an intake and a gt35r turbo boosting about 14psi making over 430whp it made 501whp on race C16!
What killing the tC man is the FE head. 2AZ-FE FE meaning Fuel Economy. Small ports.
Now do you mean the 06+ Si's or the 03-05 Si's? The k20 that was in the integra was probably a k20a2 w/ k-pro to disable the immobilizer. Now the 03-05 Civic Si's and 02+ base RSX's used a k20a3. The a3 denoted an FE style head with vtec lobes of a lesser lift. k20a2--> 200hp, k20a3--> 160hp. Now the k20 in the 06+ Si's are a k20z. 197hp
Oh, you also have to take into consideration boost on a k is def gonna be more responsive because honda is notorious for high compression. The k's run like 11:1, i believe, 10.8:1, something like that. while the 2az is only 9.6:1
Old Aug 19, 2006 | 12:17 AM
  #43
Originally Posted by 06scionsc
vvtl-i has 2 cam profiles like vtec
vvtl-i is also incorporated into not only the intake cam, but the exhaust cam as well. The vvt-i on the 2az only activates on the intake cam.
That's how these hondas have that signiture, "BrrrrrrrrrrrrrrrrrRRRRRRRRRRRRRRRRRRR!", exhaust not.
Old Aug 19, 2006 | 12:36 AM
  #44
06scionsc's Avatar
I am aware of it's control on the exhaust cam. You also may have wanted to mention the fact that the new si, rsx type s, and tsx use a 3 rocker assembly. The other fuel economy heads use a 2 rocker assembly.
Old Aug 19, 2006 | 04:11 PM
  #45
Rasta's Avatar
Yea maybe they should have put a Celica engine in our cars instead. Anyway I have decided to purchase a stock engine from some guy I know. II am going to do the head port polish Ferrera Valves, I am not going to mess with the cams vvti can be a real pain. I will probably have it done in a couple of months. I have to fix this boost creep crap and leak first. I hope it makes a big difference. I am also going to put pistons and rods later next year I want to make a least 450-500whp
Old Aug 19, 2006 | 04:55 PM
  #46
06scionsc's Avatar
After talking with our reps at work on a few occasions the main reason i was given for the choice of engine was torque. When comparing the celica and the tc the tc is considerably heavier and with the celica engine would not have been able to get out of its own way. The celica engine is a good engine but lacked in the necessary torque. If only they had just created a new motor that incorporated the torque of the 2az and the vvtl-i of the 2zz we would have had a monster for a power plant.
Old Aug 19, 2006 | 05:59 PM
  #47
/\/\ word.
Old Aug 20, 2006 | 04:33 AM
  #48
3min3m2's Avatar
Originally Posted by thisisdudewhoru
Originally Posted by tCUZZ
its the vtec. every honda dyno graph I have seen, the hp sky rocket after vtec kicks in.
No doubt the v-tec produces more horsepower than the VVT-I but cmon..stock to stock the engine only has 40hp than ours...we have more torque than they do.
What's your point. Stock for Stock we have less hp than an SRT-4. Put us on 8 PSI of boost, and we put down more power than an SRT-4 (forget what PSI setting they come with from the factory). So, you can't compare totally two different engines.
You should check back on that k20 Teggy from time to time to see how long it last, IF it was stock internals. They come with like 11:5.1 HIGH compression pistons in them. I'm just curious to see how long that motor last like that. All the New 06 Si's in the mags, that have been F/I, 99% of them all had different LOWER compression pistons in them. NONE were using stock pistons.
20-22 Psi stock for an SRT-4
Wrong! I have an srt4 and from the factory it is set at 14lbs of boost.
dang...imagine a tC on 20-22 PSI......heck 14 PSI is pushing a lot of hp on the 2az...
give it time man....civic have been around forever, tC is going into its 3rd model year.....
Old Aug 20, 2006 | 03:28 PM
  #49
killerxromances's Avatar
uh, k20z in the Si is newer than the 2az, and whats with every other tc owner comparing the tc to a civic? Its been like that since it came out, and whats with everyone wanting to compare vvti to vtec? Two completely different systems reguardless of its simularity with the cams.
I keep saying it, i hate the 2az and as i've always said, the 2az's potential isn't that great. Sure it can make good numbers, but at what cost? Time will tell. I know rythmn wont ever admit that the 2az isn't as great as he believes, but i actually agree with you on one thing. High compression and high boost is a death trap. Lower the compression, and do minor upgrades with the internals and that 500whp would be much more reliable.
I keep getting sh_t on here, yet it always seems what i say is proven at a later time. Supercharger is crap for the money. People gave me crap, until people started having various issues. Supercharger is a waste on the auto, gave me crap until someone posted numbers.
Old Aug 21, 2006 | 01:46 PM
  #50
Rasta's Avatar
Thats what I am sayin
Old Aug 23, 2006 | 02:07 AM
  #51
deflaytedwayz1's Avatar
but jumping back into the conversation earlier. wouldn't a zpi stage 1 or 2 head help out immensely?
Old Aug 23, 2006 | 06:36 AM
  #52
Joe_Dezod's Avatar
I still havent seen dynos of those different stage heads so I'm unsure what it does yet. But yes a ported head will help. How much? I don't think anyone really knows because I have not seen any before and after dyno comparisons. If I misseed it I'd love to see it. We're currently designing new head packages as well so I'm looking to see what has worked and what doesn't. I know we're taking our time wiht our race head upgrades.
Old Aug 23, 2006 | 01:20 PM
  #53
Rasta's Avatar
Yea I am interested in seeing the difference, funny how come this never came up before? I was going to purchase an engine from a guy but he sold it. How long before you guys finish with yr head?
Old Aug 23, 2006 | 02:15 PM
  #54
peteyd's Avatar
Maybe I can talk kenny into sendin me a stage 1 head and ill do a predyno with my stage 1 turbo and then redyno after I put the head on. ill see what he says and let you guys know.
Old Aug 23, 2006 | 05:23 PM
  #55
cessblood's Avatar
Are you sure it's 20-22 PSI for a stock STR-4? One of my best friend has one and we seen 8 PSI on the SRT 4. My other friend has an EVO and is pushing 16PSI. I got say I love the EVO now
Old Aug 23, 2006 | 05:46 PM
  #56
cessblood's Avatar
The 501whp by the way was at 17psi on racegas
And just how much hp do you think a tC would make on 17 PSI and racegas? We just need more time to push the motor that far. The car has only been out for what 3 years.
I agree with you rhythmnsmoke
Old Aug 23, 2006 | 05:50 PM
  #57
cessblood's Avatar
Originally Posted by Nu_ERA
All are right in my book so far. Car is still new and head work is one of major keys to unlocking good power. Along with a built bottom, head is getting major face lift along with titanium goodies and what not. Guy who is building my motor told me that usually Supra owner can spend over thousands on the head alone.
I agree with you too Nu_ERA
I heard about the Supra owers spend alot on their heads also.
Old Aug 23, 2006 | 06:34 PM
  #58
EvolutionxB's Avatar
The reason for lower horsepower could be related to a variety of reasons. Engine management, Air/Fuel ratio, exhaust flow and back pressure, intercooler size and turbo boost. Plus, consistent performance is more important than 501 hp dyno runs. Who knows how that car would run after heat soak.
Also, are you considering how much was invested in that car compared to yours? And what the owner of that vehicle could have purchased with the money invested+the car? 25k+ for the car (probably 27,000 out the door), then maybe at least 10k in modifications and tuning. He could have bought a real car, ie, STi, Evo or Corvette. Cars that can turn and accelerate consistently.
I sincerely doubt that Acura was running with stock internals. Forced induction cars can't run with 11:1 compression, they need the lower compression to compensate for the higher amounts of air being forced into the cylinders. If it was stock, I wonder what kinds of issues that car is having now.
Stock maximum boost is 15 psi for Dodge SRTs.
Evo's boost 1.5 Bar all day, thats almost 21 psi.
Old Aug 23, 2006 | 06:42 PM
  #59
ProshopXB's Avatar
After more reaserch it is 11-14 psi, my freind likes to tell fish stories i guess if you know what I mean.
Old Aug 23, 2006 | 06:48 PM
  #60
Not trying to flame you, but you should check your facts before you post.
