Monster Motorworks TC Supercharger Intake W/Dyno!
Originally Posted by soros151
Can the 07 tC use it as well?
Actually the stock AFR is almost the same with the flash for the S/C exept the stock only adjusts a little up top. Both remain at 14.7, except the S/C lowers the AFRs at 4000+RPM. Still the way that map is already lean, this intake doesn't change too much, but adds to the paranoia.
i think is better to run the stock air box with a k&n filter because that filter exposed like that will get some major heatsoak when the engine gets warmed up after some driving at that point you will loose some ponies
for all you supercharger guys i would just run the stock airbox with the bottom removed. Cut the lip off the box tho so you have something to hold your stock filters in with. Im willing to bet it will be the highest hp available for the s/c. The power comes from the air flowing through the maf sensor mount and its ability to read it correctly. Belive it or not toyota knows what they are doing.
i didnt mean the s/c design i ment the intake routing and maf design.
btw the thread i started just asked if anyone knows anything about the trd reflash. exactly what it changes specifically and hp number diffrances. richer, leaner, ignition changes etc.
https://www.scionlife.com/forums/vie...599&highlight=
is it me or do the welds look a little sloppy...like on the maf port and on all of the curvy parts of the pipe?
also for heatsoak...MM has an 'air box' for their other intakes. would that help?
the air box should help some, but i there isn't one available yet for this intake. there's a pic i posted a long time ago that showed someone taking the temp under the hood and then also taking the temp inside of the air box. i can't remember what the diff in temp was-maybe like 10 degrees difference inside and outside of the box.
Ok, this is a question for MMW. The intake in the first picture looks NOTHING like the one posted on the top of this page. So my question is: If the intake on the first page made 9.5whp/8.5wtq, how much does the one you are selling make? They are clearly not the same intake, so results may vary. Thanks in advance
well if you look at the first pic, you can see that sharp bend and it doesn't curve back towards the front of the car, but rather it seems that they cut the stock silicone hose. The picture at the top of pg.3 , it has several small bends, as opposed to one sharp one. Also you can see it curves all the way towards the front eliminating the silicone hose altogether and only needs couplers. Maybe I'm just trippin' but they don't look the same to me. could be the angles
