My install is done
Old May 27, 2006 | 05:31 PM
318_tC's Avatar
Default My install is done
dezod kit installed on the auto but the car is broken down on the side of the road. score. Idles great, Run's great, but chrage piping wont stay on for ____. Soon as I give it any kinda throttle BAM there it goes. Other than that everything is straight for the most part. Ill post pics if i ever get the car off the sie of the road. I dont even want the damn car anymore after the instal
Old May 27, 2006 | 05:41 PM
exige's Avatar
reasons and more details....
Old May 27, 2006 | 05:49 PM
zer0's Avatar
Tbolt clamps and some hair spray will keep those charge pipes on...
Which pipe keeps blowing off?
Old May 27, 2006 | 06:33 PM
BlkSandPrlTurbotC's Avatar
T-bolts and Rave Ultra Hold hairspray
Old May 27, 2006 | 07:42 PM
KJIN's Avatar
Default Re: My install is done
Originally Posted by 318_tC
dezod kit installed on the auto but the car is broken down on the side of the road. score. Idles great, Run's great, but chrage piping wont stay on for poop. Soon as I give it any kinda throttle BAM there it goes. Other than that everything is straight for the most part. Ill post pics if i ever get the car off the sie of the road. I dont even want the damn car anymore after the instal
wow, that sucks big time. why didn't dezod provide Tbolts with their kit?
Old May 27, 2006 | 08:55 PM
318_tC's Avatar
Ok shes back up and running. They did provide Tbolt clamp's but when I get on it I blow piping off. Im just driving like a grandma now. Ill try the hair spray idea.
Old May 27, 2006 | 08:57 PM
peteyd's Avatar
and your coming down when?
Old May 27, 2006 | 09:22 PM
318_tC's Avatar
^im calling jason tuesday so ill know then
Old May 27, 2006 | 09:25 PM
zer0's Avatar
Is there even a lip on the Dezod pipes?
Spray some hair spray on the pipe where the coupler will go, then tighten the clamp and coupler as hard as you can, works everytime.
Old May 27, 2006 | 09:28 PM
pollup's Avatar
just curious, hairspray? where do you spray the hair spray? on the inside of the couplers? interesting.
Old May 27, 2006 | 09:30 PM
zer0's Avatar
Spray a thin layer of hairspray on the joiner in your troublesome area. Assemble the parts and wait 30 minutes for the hairspray to dry. This will make the surface sticky to hold pieces together and prevent leaks, but not strongly adhere or damage anything. Many people use hairspray on every connection - not only does it make for better connections, but it also makes pieces easier to slide together when you first apply it.
Old May 27, 2006 | 09:31 PM
pollup's Avatar
good info to know, if i run into the same problem i will likely use this. i also had a problem blowing charge piping, but then i torqued the clamps down to the point where i broke 2 of them and had to replace, so they are stupid tight .
Old May 27, 2006 | 09:32 PM
Scott8's Avatar
And it smells GREAT!!!
Old May 27, 2006 | 09:50 PM
Hairspray is the oldest trick in the tuner world for couplers/charge piping when doing turbo systems
The hairspray acts like a glue like zer0 said :D
I use Rave Ultra Hold (baby blue tall can)
works good to when i gel spike my hair too hehe
Old May 27, 2006 | 10:19 PM
paul_dezod's Avatar
Scionetics
KAD
Torque those T-Bolt clamps tight. Your pushing some serious pressure those pipes.
Old May 27, 2006 | 11:29 PM
ZPIracing's Avatar
The pipes need to be bead rolled. All the glue in the world will not keep the pipes in the couplers.
Old May 28, 2006 | 12:20 AM
Joe_Dezod's Avatar
I guess just torque the provided t-bolt clamps more
I haven't used an ounce of hair spray on mine and I haven't blown a pipe yet, and we've pushed almost 12 psi.
Old May 29, 2006 | 06:51 AM
318_tC's Avatar
Thats what my installer said.
Well she is up and running with no problems what so ever. Im so happy too!!
2 Run's so far. A 99 honda civic boosted si and a 02 booster sohc civic
lost by a car to the boosted si and beat the sohc. good runs!!
Old May 29, 2006 | 06:55 AM
ddsboi's Avatar
u gonna dyno?
Old May 29, 2006 | 01:10 PM
paul_dezod's Avatar
Scionetics
KAD
Congrats!!
