Is my turbo'd tC really a hybrid in disguise?
So I got up early this morning and drove from Virginia Beach to just outside Cleveland. A drive I've made a bunch of times before. I run a ZPI kit, with 550's, tuned with blue (tune is about 2 years old). Normally freeway driving I average between 20-25 MPG... That was with quite a few exhaust leaks and such. I just replaced all the gaskets and such on the kit. I filled up at my halfway point, which was 307.7 miles and my car took 8.169 gallons... doing the math, I averaged 37.6 MPG.... I'm perplexed. I topped off before leaving VB, made sure to reset the trip odometer and I drove with the AC on the whole time, cruise on set at 65 majority of the way...
I'm not complaining at all, but dang!
Hot weather helps mileage and you were not empty so the gas that was in the tank was warm and expanded - your next fillup will get you lower mileage more than likely. You could also have lucked out and got some extra gas due to some pumping error. You should get about that mileage at that speed if everything is well tuned.
that is odd jan... I usually get my best mileage on a tank when I fill up in the middle of the night and my tank is almost bone dry. it also varies significantly depending on the exact station I fill up at (presuming it has something to do with the ethanol content)
If you fill up and drive a few miles then fill up again, the gas that was in the tank expands so it looks like you didn't burn much at all but you really did and eventually you do get the correction to your mileage after you burn the expanded gasoline.
im actually working at dezod motorsports for the summer and i was told that it depends on the way u drive. if ur nice to the car (not reving it to max rpm's) then it would b like a hybrid. its because ur using the exhaust air to spin the turbine which spins the compressor wheel which then goes into the intercooler and pushes the air back into the throttle body and cycles like that. and if ur pushing ur car to the max then it can b the complete opposite, a gas guzzler.
so to wrap it up it can b if u treat it right.
gedster314
14
Nov 17, 2018 02:56 PM
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
umnitza
Sep 1, 2015 08:06 PM
