Need help with FIC Harness
Old Apr 28, 2011 | 03:10 AM
car_ram_rod's Avatar
Default Need help with FIC Harness
I hate to make a new thread, but I can't find close up pics or the proper pinout/wire color for this. I was going to tap from pin 18 to my wideband so I can log my wideband with the FIC. Anyway, when I was pulling the 22pin connector off 2 wires also pulled out and I can't find where they go. I'm almost positive they should go on the far left pins somewhere....
22 21 20
11 10 09
Any help would be much appreciated
Old Apr 28, 2011 | 08:59 PM
crush02342002's Avatar
Old Apr 28, 2011 | 09:47 PM
sci0n-tc's Avatar
22 21 20
11 10 09
Attachment 4966
I am actually curious witch wire i need to hook my wide ban gauge wire to data log also ...
I'm assuming that I connect my wide band analog wire to the white login wire correct??
Sorry to but in on your post
Old Apr 28, 2011 | 09:50 PM
Awesome thank you Crush!! My harness does not have an aux in so I'll have to pin it...Anyone know of a place to find the right size female pin for this harness?
Old Apr 28, 2011 | 09:55 PM
The log wire is just there to hook up to a switched ground to start the internal data logging. The aux in is where you would land your 0-5VDC sensor. You just need to set up the parameters in the FIC software ie. 0-5V = 7.35 - 22.39 A/F for the innovate wb.
Old Apr 29, 2011 | 10:44 AM
see above pic
Old Apr 29, 2011 | 10:53 AM
if you have the universal harness and if your lucky you can pull a pin and wire from the uni harness (thats one big IF..lol)
I do have some laying around but not sure where, i got em from http://www.alliedelec.com/search/pro...px?SKU=8630537
good luck
SloTC1
Aug 16, 2018 02:45 PM
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
prescottn
Oct 8, 2015 05:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
brett561tc
Sep 15, 2015 06:33 AM
