Need help with ignition wiring for Defi Racer gauges
I have a Defi Racer boost gauge and oil pressure gauge I need to install. I've searched all around the forums to figure out where I can a wiring diagram for the ignition harness. Can anyone tell me what the color of the wires are for a 12v constant power, 12v when the ignition is on, a 12v illumination wire when the lights are on, and a ground. If anyone can help me out figuring out what the colors of the wires are, I would appreciate it!
where do you want it tapped? the best thing to do is use a multimeter and you will be sure rather than going by colors.. I tapped power for my EDFC before on my radio harness and some wires are stripped with 2 colors
there's a post in here with wiring diagram, ill try to search again.. but i advise you to always verify it with a multimeter, or else you could drain your battery if you tap it wrong
I will definitely use a multimeter, I just wanted to know where to start when I tested. I'm going to be mounting the gauges in an a pillar pod, so wherever it would easiest to tap into.
Originally Posted by Ace83
Originally Posted by crush02342002
im a little curious why you want to use an illumination lead.
iv got an 07, i dont think the wireing really changed as far as illumination and other 12v switched sources except for the harness to the computer but i didnt go anywher near the computer for the taps.
