need help on turbo timer
Hi i have the greddy electronic turbo timer and need help installing it any help would be great. i know what wires it needs to be hooked up to but cant find them, also i am thinking that i am going to t-tap the wires do you think that is fine
yeah, 3-4 t-taps, and some crimpers....the wires you need to tap into, or at least where i did mine was under the steering column.....just crank your wheel allthe way on direction, and theres a screw, then do the same on the other side, then the plastic covering will come off, and you can tap the wires there....forgot the exact color combinations to the wires though, lol
ok in the greddy book it says that a standart ignition has the following wires
12v- 12 volt constant power
on- ignition power
acc- accessory power
and that som car ignitions have two ignition power wires i am wondering what color the wires are that i need to tap into i beleive that the 12v wire is red and that one of the ignition wires is yellow but not positive. could really use some help
on- ignition power
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
SJMiller
Sep 12, 2015 06:33 PM
