nitrous questions
nitrous questions
Ok i have a 05 Tc and I just bought a NX wet kit. I have a few questions.... What plugs should I run, I plan on starting with a 50 shot and working my way up to a 100. Part numbers would be apprecieted. Also what jets is the 50, 75, and 100 shot. Thanks everyone!
Not to be a jerk, but if you can't figure out what jets are what (shot wise) I would not install it yourself........With the ZEX kit that I have sitting in my room, the manual said what each jet was and they matched o each number on the jet its self........I was told that you should go two steps colder on the spark plugs....
Originally Posted by tc4u2nv
you dumb son of a preacher...I bought a used NX kit and dont have anything thing to go by. so what is the jets im supposed to use for the 50, 75, and 100 shot??? I need part numbers for the plugs, i know 2 steps colder u dumb poop. thank you dumb poop.
I bought spark plugs that were 2 levels colder. It has been a while since i bought them so i don't remember what brand they are..but 2 levels colder is what i got runs wonderfully...make sure you keep your stock sparks just incase something goes wrong with your Nitrous and you need to take it back to the dealer
As far as jets, i dunno if you found your answer (i didn't read everyone's posts)
This is the guide i've used and havn't had any problems:
HP N2O Fuel
35 31 18
50 35 20
75 41 24
100 52 28
Hope this helps
HP N2O Fuel
35 31 18
50 35 20
75 41 24
100 52 28
Hope this helps
if i was you i use a 50shot try to use less then 50%hp of the car hp , if you want to go higher then get more bolt-on's kits like CAI, Header, S-pipe, Exhaust, and some pulleys and a stage 3 clutch, lots of parts and money but if you want your car to be safe that the only way so if i was you i use 50shot. so good luck and be safe. Oo ya if you going to race with NO2 dont use it more then 3 times or races keeps it from fring your pstions rings
You also may want to take it to the dyno and let them configure everything, that way you know you won't be running too rich (too much fuel) or too lean (too much N2O)...If you're unsure of what's goin on, it's best that you run rich. You will lose a little power, but i'd rather lose a little power rather than lose my engine
