Oil pressure gauge please help
Old Sep 1, 2006 | 06:04 PM
Byta27's Avatar
Default Oil pressure gauge please help
hey guys do u think that this oil pressure gauge willl be ok for the tc ? do i need the 0-100 psi gauge cause this is the one i just ordered
https://www.rpmoutlet.com/ezRetail/s...hp?msg_id=2101
Old Sep 1, 2006 | 07:36 PM
jam0321's Avatar
that will work fine. your pressure will vary from 15psi to 80psi depending on your setup.
Old Jan 12, 2007 | 03:55 PM
RedScionFusion's Avatar
Have you installed your oil pressure gauge yet? Im installing mine and im just wondering what T-Clamp size fitting did you use when installing your oil press. gauge? Thanks
Old Jan 12, 2007 | 03:57 PM
SickleCell's Avatar
Mine rarely goes above 80psi...... I got mine from glowshift and it replaces the stock oil sender unit which is on the front ride side of the engine.
Old Jan 12, 2007 | 04:17 PM
318_tC's Avatar
if its a mechanical gauge, dont use it.
Old Jan 12, 2007 | 04:27 PM
zer0's Avatar
The one in the link he "orderd" is electrical. It will do the job just fine.
Old Jan 12, 2007 | 05:13 PM
The oil pressure gauge i got is from glowshift and do i replace the stock sending unit or just install the new sending unit together?
Byta27's Avatar
I have the same exact gauge very good gauge, u will like it.
Old Jan 12, 2007 | 05:17 PM
how did you install it?
Old Jan 12, 2007 | 05:19 PM
zer0's Avatar
Oil block adapter that fits 1/8" threads.. like this
http://cgi.ebay.com/ebaymotors/OIL-F...mZ320068775621
Its universal it will fit your car, its the same one I have.
Old Jan 12, 2007 | 05:31 PM
do i really need it? cant i just replace the stock sending unit with the one they gave me?
Old Jan 12, 2007 | 05:33 PM
TCpete's Avatar
is there a good DIY for installing this??
zer0's Avatar
You can tee it off, by buying a brass fitting from the hardware store. But IMO the sender(electrical) looks cheesy and out of place in the engine bay. I dont know the exact sizes needed so your on your own.
Old Jan 12, 2007 | 05:36 PM
ok thx man apperciate the help
Old Jan 12, 2007 | 07:40 PM
yamaha16bw's Avatar
Yeah get a oil block adaptor. And dont remove the stock oil pressure sender.
Old Jan 13, 2007 | 04:01 PM
ok i will thx do they make oil adapters just for the tC or is their universal 1's?
Old Jan 20, 2007 | 06:15 AM
kamileon's Avatar
My oil filter adapter from glowshift does not fit. Its the right threat just the adapter nut isnt long enought to screw into the block bolt sercurly. What should i do? I contacted glowshift and got no response, how did everyone else get thiers to work? I just have oil temp gauge to tap in
Old Jan 20, 2007 | 12:27 PM
yamaha16bw's Avatar
I use the greddy one and fits just fine. How long you been trying to get ahold of them? I would just buy one off ebay like zer0 said.
Old Jan 20, 2007 | 05:27 PM
kamileon's Avatar
i did buy it off ebay
Old Jan 20, 2007 | 05:30 PM
kamileon's Avatar
12002736US $ 60.44E Type, O Ring 72mm/76mm, Center bolt Pitch M24 X P1.5, Center Plug Bolt 1/8PT X 3 M12 X P1.25 X 1
12002737US $ 60.44F Type, O Ring 72mm/76mm, Center bolt Pitch M26 X P1.5, Center Plug Bolt 1/8PT X 3 M12 X P1.25 X 1
12002738US $ 60.44G Type, O Ring 72mm/76mm, Center bolt Pitch 1-12UNF, Center Plug Bolt 1/8PT X 3 M12 X P1.25 X 1
12002801US $ 47.80Standard Type, O ring 56mm/65mm, Center Bolt Pitch 3/4-16UNF,M20 X P1.5 Center Plug Bolt 1/8PT X 2 M12XP1.25X1
12044000US $ 47.80FD3S Type O Ring 60mm Center Attachment 1/8PTX2 Plug Bolt attached
What size?
