P0335?
Just wondering how common it is to get this crank position sensor failure code for other reasons. After much trial and error testing I had an FIC working pretty well on my 08 XB with no resistor on the crk and a 2.2k on the cam until I tried removing the cam resistor. After removing the cam resistor I got an immediate P0335 and the car was undriveable so I removed the FIC. That's when I discovered that my ND K22PR-U plugs were fouled and couldn't fire the ~10:1 AFRs I get in open loop without the FIC to compensate for my larger injectors. I expected misfire codes but instead only got the P0335 CEL. I replaced the K22s with NGK BKR7EIX iridiums and all the plug issues are gone.
So... I'm wondering if fouled plugs could cause a P0335 CEL during high load/rpm conditions? Not asking for theoretical postulations here, just first hand experience please. |
Originally Posted by ScionFred
(Post 3474768)
So... I'm wondering if fouled plugs could cause a P0335 CEL during high load/rpm conditions? Not asking for theoretical postulations here, just first hand experience please. I can say ive hard cars that had fouled plugs that did not run.. And they did not have a crank sensor code. |
Originally Posted by ElevationTC
(Post 3474895)
You know.. There is a unit called greddy emanage ult :)
it would work wounders here i beilve! |
That's plan B.
