Prosport wideband to AEM F/IC
Need help on understanding how to connect my wideband to the AEM F/IC.
The wideband kit came with a little black box that all wires plug into.
-02 sensor
-Gauge
-Power source
-Analog output
Analog Output
Wire colors
Black= Engine ground
Brown= Wideband analog output 0-5V (0V to 10AFR, 5 to 20AFR)
Green= Narrow band analog output 0-1V (0V to 20AFR, 1V to 10AFR
On the AEM F/IC, came to extra wires.
Wire color
White= Login
Light brown= UEGO
My question is witch Analog output wires should i use to connect to the F/IC wires.
My gut tells me to hook up the BROWN wideband wire to the AEM WHITE login wire, but don't I need NARROW BAND hooked up also to tune full rpm rang?
Any input would be appreciated thanks
-02 sensor
-Gauge
-Power source
-Analog output
Analog Output
Wire colors
Wire color
White= Login
Light brown= UEGO
SloTC1
08-16-2018 02:45 PM
