PTUNING: 3" Exhaust Dynoed with TRD S/C (Results are in
Old Dec 19, 2007 | 11:56 PM
Guest
Guest
Posts: n/a
Default PTUNING: 3" Exhaust Dynoed with TRD S/C (Results are in
We've had numerous inquiries from supercharged tC owners asking whether or not we've tested our 3" exhaust system on a tC with a TRD S/C. We recently brought in an '05 tC with a TRD S/C running a stock 7psi pulley, for testing. We were skeptical about whether there would be any power gains, since we felt a 3" exhaust was a bit large for a S/C tC. Our intuition told us that we might gain some power up top, but possibly lose power down low and even in the midrange. Our dyno, however, proved us wrong.
We dynoed the TRD S/C tC with the following exhaust configurations all within a 4-5 hour period. The temperature was between 55-57degrees in our dyno cell during all the dyno sessions.
The car came in equipped with a stock header, stock S-pipe and TRD axle-back exhaust. This set-up provided us with the baseline information.
We then proceeded to test the following exhaust system configurations:
- PTUNING 3" full turbo-back exhaust - or in this case we'll call it a "header back".
- PTUNING 3" S-back exhaust with factory S-pipe.
- Megan Racing S-Pipe and Megan Racing 60mm drift-spec exhaust system.
Updated: 12/20/2007
The dyno results are in. Sorry it took so long, but it takes time to get all the graphs and crunch the numbers. Let's see who guessed the right set-up.
Baseline dyno number
RUN: 062237.004 (baseline)
-TRD S/C w/ standard 7psi pulley
-stock s-pipe
-stock mid-pipe w/cat
Below is a graph showing that we are testing a 7psi pulley
Baseline vs PTUNING 3" Turbo-back/Header-back Exhaust
-stock s-pipe
RUN: 062237.008
-PTUNING 3" Turbo-back Exhaust
Max Gain Over Baseline
HP: 13.7 WHP @6300
TQ: 12.0 FT/LB @5650
Peak Gain Over Baseline
HP: 10.4 WHP
TQ: 6.8 FT/LB
Baseline vs PTUNING 3" S-back Exhaust
-stock s-pipe
RUN: 062237.013
-stock s-pipe
-PTUNING 3" S-back Exhaust
HP: 5.7 WHP @5900
TQ: 6.0 FT/LB @3550
HP: 3.4 WHP
TQ: 4.1 FT/LB
Baseline vs MEGAN 60mm Drift-Spec Exhaust + Megan S-pipe
-stock s-pipe
RUN: 062237.019
-Megan S-pipe
-MEGAN 60mm Drift-Spec Full Exhaust
HP: 4.9 WHP @5900
TQ: 5.0 FT/LB @4150
HP: 2.5 WHP
TQ: 4.2 FT/LB
PTUNING 3" S-back Exhaust vs MEGAN 60mm Drift-Spec Exhaust + Megan S-pipe
RUN: 062237.013 (baseline)
-stock s-pipe
RUN: 062237.019
-Megan S-pipe
PTUNING 3" Turbo-back Exhaust vs MEGAN 60mm Drift-Spec Exhaust + Megan S-pipe
-PTUNING 3" Turbo-back/Header-back Exhaust
RUN: 062237.019
-Megan S-pipe
Baseline vs MEGAN vs PTUNING 3" S-B vs PTUNING 3" T-B
I hope you enjoy the info. It was a lot of work on the dyno, on the lift and on the computer.
Happy Holidays,
MrC
Old Dec 20, 2007 | 12:23 AM
2_much_tc's Avatar
this is definitely something i will be watching... i want to know the results!
Old Dec 20, 2007 | 12:50 AM
BuddhasTC's Avatar
i hope you do a dyno of the car without the exhaust also so we can truly see the difference
Old Dec 20, 2007 | 02:31 AM
kanundrum's Avatar
:D
Old Dec 20, 2007 | 02:44 AM
JPsTc's Avatar
1UP Crew
^Im really curious to see what numbers it put out
Old Dec 20, 2007 | 02:46 PM
fdkumro's Avatar
Results? You have the info, whats the point of making us all wait?
Old Dec 20, 2007 | 03:08 PM
kanundrum's Avatar
They have to get the Dyno Results posted. Chillax.
Old Dec 20, 2007 | 03:14 PM
fdkumro's Avatar
Not upset, just don't understand why some companies do things like this. Everyone knows waiting is no fun :-P
Old Dec 20, 2007 | 06:46 PM
2_much_tc's Avatar
^ not every works at warp speed... but I can't wait to see them. I'm gonna go out on a limb here and guess about the results, we all should until they get posted. I have a feeling... the factory s-pipe with the 3 inch exhaust got the most power...
Old Dec 20, 2007 | 09:17 PM
Guest
Guest
Posts: n/a
The dyno results are in, see the first post. Sorry it took so long.
Enjoy,
MrC
Old Dec 20, 2007 | 09:24 PM
jrodTc's Avatar
Nice results. Interesting to see that the S-Pipe really does appear to be one of the more restricting parts of the exhaust.
Old Dec 20, 2007 | 09:55 PM
2_much_tc's Avatar
it's should be obviously clear that the 3 inch exhaust is the way to go. the results are great. thanks ptuning. now i got to save up some $$$ for the exhaust.
Old Dec 20, 2007 | 10:18 PM
kanundrum's Avatar
Thanks for using my car as the beta tester! Hopefully we can get a great idea on exhaust components now.
Old Dec 21, 2007 | 12:07 AM
Scott8's Avatar
Would the cars do better with a 2.5" exhaust over the 3"???
I thought 3 inch exhaust was for high power applications or big V8's?
Old Dec 21, 2007 | 12:17 AM
2_much_tc's Avatar
^ the megan exhaust is 2.5 all the way back... and it only made a slight gain according to the results...
Old Dec 21, 2007 | 12:18 AM
jjos1's Avatar
Wow nice numbers to back up a product now all we need is an intake manifold to go with it.
Old Dec 21, 2007 | 12:21 AM
Scott8's Avatar
I meant a Ptuning 2.5"
Old Dec 21, 2007 | 03:32 AM
2_much_tc's Avatar
i don't think that the results would be that much different. maybe the guys from ptuning can chime in...
Old Dec 21, 2007 | 05:29 PM
Guest
Guest
Posts: n/a
After seeing the result with the 3" turbo-back, we can conclude that a S/C tc likes a fully unrestricted system. I don't think a full 2.5" system is going to make more power. Since we did not see an power loss at the low to mid-range with the 3" system, but instead we actually saw a slight gain at the low-end and we actually saw a big gain on top with a full 3" system.
At this point we will say that the 3" turbo-back is the way to go for even a S/C system--it's obvious that the S/C cars does not need any back-pressure for exhaust scavenging like a N/A car. The gains on top will be even more significant for those running a 9 psi pulley with the 3" turbo-back system.
MrC
Old Dec 21, 2007 | 07:29 PM
SLIVER007's Avatar
I have had my 3' turbo back for about a month now and love it. I gained 23 whp and 19.8 TQ
Good job guys!!
