ptuning intercooler question
Old Jul 19, 2012 | 01:49 AM
thehundreds702's Avatar
Default ptuning intercooler question
I have the greddy kit for my 07 tc; but the intercooler got damaged from the previous owner. Will the ptuning intercooler be a direct swap? they both have 2.5 in/outlet. Just wasn't sure about the piping matching up.
any info will help.
thanks!
Old Jul 19, 2012 | 02:11 AM
tcracer09's Avatar
I'm pritty sure its a direct fit as long as the in/out are the same size as ur piping than u shouldn't have any problems, I'm running ptuning turbo kit on my 09 TC.
Old Jul 19, 2012 | 09:50 AM
tcracer09's Avatar
Also forgot to mention for a direct fit make sure the measurments of ur greddy intercooler is the same for the ptuning intercooler. And if the ptuning intercooler is wider than ur gonna have to trim ur piping to make it fit.
Old Jul 19, 2012 | 03:47 PM
okay thanks; also when you installed your ptuning intercooler; did you have to make a bracket for the top support to attach it to the hood latch?
Old Jul 19, 2012 | 03:52 PM
tcracer09's Avatar
The bracket comes w the intercooler to attach it to the latch
Old Jul 19, 2012 | 04:31 PM
headlessmunky's Avatar
I would measure both of the intercoolers. If they are the same in width you should be okay. If there is a difference in thickness and height it shouldn't be too much of an issue.
Old Jul 19, 2012 | 05:52 PM
Mine didn't come with one and I called them and they told me I need to make one
Old Jul 20, 2012 | 07:30 PM
PTUNING's Avatar
any info will help.
thanks!
Our FMIC kit was designed specifically for the PTUNING Spec-SS turbo kit.
Therefore, even if the intercooler size is the same as the GREddy, most likely the two end IC pipes will not line up without modifications.
Our intercooler does come with 2.5" outlet.
Best Regards,
Mike @ PTUNING
Old Jul 20, 2012 | 07:38 PM
PTUNING's Avatar
The PTUNING FMIC kit does come with 3 pre-welded brackets.
Two on the bottom and one on top (for the latch).
Therefore, if you already have the PTUNING Spec-SS turbo kit, this FMIC kit is a directly bolt-on.
However, if you are using the FMIC kit with a different turbo kit, you will need to make the bracket for the latch.
Hope this help.
Best Regards,
Mike @ PTUNING
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
