pulley ?'s
Re: pulley ?'s
Originally Posted by lilsouljahboy
i just bought a nst 9.5psi pulley do i need to reflash the cpu since it was already done when i had the s/c put on from the factory?
nope - just once. BUT if you want to jump up a step and get a tuneable ecu (piggyback) then you can prob get another 20hp ontop of whatever you will get from the other pully. The power is there but just needs to be tuned.
Also with that pulley I reccomend going to a 7 heat range- 8 heat range spark plug "colder" Would be the smart thing to do with that kind of boost. I personally am running a IK24 in mine with the nst pulley "8 heat range". Perfect heat range so far!
Originally Posted by Garage1217
ik24 is a denso spark plug. I carry them on my website as well as NGK
Are you running into the oil leakage from the shaft of the charger like most people are ? (i dont know if i make sense) LOL
Nope, no problems at all. Also that is only a tiny handfull of people. the drama queens on the board makes it sound like lots of people are having the issue. I think like only 2 are actually verified to have the problem.
You will be ok as long as you had TRD reflash your ECU when they first installed your supercharger. I just checked www.nonstoptuning.com and it shows their project tC actually runs really good air/fuel ratios at 9.5psi.
So you should be fine.
