Question!
Old Mar 14, 2009 | 04:41 AM
scion_andrew's Avatar
Default Question!
Ok im trying to put together my own stage 0 set up my question is What manifold would fit the BIG 16G Turbo Turbocharge EVO 3?? beacause the flange on that turbo looks like it would not match up to the t3/t4 manifold flange...
Thank you!
Old Mar 14, 2009 | 05:08 AM
tC_2NeR's Avatar
You would have to have the flange for tye 16g welded on...
Right now i think nobody makes manifold for a 16g turbo
Save urself the trouble just get a t3t4
tC_2NeR's Avatar
Or u can find an old zpi manifold
Old Mar 14, 2009 | 03:46 PM
Ah thats what i was thinking .. well i dont wanna have it welded and i know it would be hadrd to find a zpi manifold... thank u !so i f i did go with a t3t4 turbo which one would be the best for a stage 0?
Old Mar 14, 2009 | 03:48 PM
XIEmperorIX's Avatar
Why not just check the PPC section? ZPI stage 0's show up there every once in awhile.
If you're bent on going custom then ignore me
Old Mar 14, 2009 | 10:50 PM
rhythmnsmoke's Avatar
Music City Scions
Vulcan Turbo makes log and EL manifolds with a Mitsubishi flange.....which is what the 16G uses. Or you can get any other flange on there.
OP....search for Vulcan Turbo on here, or you can go to their website.
http://www.vulcanturbo.com/Scionmanifolds.html
Old Mar 14, 2009 | 11:32 PM
crush02342002's Avatar
check around here about vulcan turbo first before you order...i havnt heard anything from them in quit a while...
Old Mar 15, 2009 | 03:21 AM
m6ar2cel6oTC's Avatar
That's cause the guys been missing. I ordered a manifold from Vulcan about 3 weeks ago and no manifold either nor phone call. Beware of Vulcan. I have a manifold for sell pm me or check the classified section for manifold.
Old Mar 15, 2009 | 03:50 AM
you cant get ahold of them? i hope you get either your money back or your mani...good luck bro
Old Mar 15, 2009 | 05:00 AM
BlackKnight's Avatar
Music City Scions
Why not just get a t3/t4 with smaller a/r's if you are worried about spool this way you will have a lot more options if you decide to upgrade.
Old Mar 15, 2009 | 05:23 AM
^can you send me a link for the best turbo i can use . I dont know which t3t4 to go with!
Thanks!!!!
Old Mar 15, 2009 | 05:38 AM
Music City Scions
What are your power goals and do you want a ball bearing or non?
Old Mar 15, 2009 | 05:56 AM
for now i want something for about 230-250hp, I already have the intercooler to run on the setup with the 5.8psi spring in the waste gate NO manage system or tune with sock injectors. And maybe eventualy upgrade, but will probably run like this for about 2 yrs hopefully without problems!
So what turbo would you suggest?
Old Mar 15, 2009 | 07:43 AM
Music City Scions
not to be a d-ck but I wouldn't turbo any amount of boost without management!
Boost with no managment = a lose situation from the start. Do not do it!
Turbo maybe something like this http://www.dezod.com/pd-garrett.cfm
Old Mar 15, 2009 | 03:55 PM
if i were you atleast buy like a emanage or something cheap as fuel management to atleast help out! cause a custom stage 0 with no management will hurt you in the long run. or get a turbo with similar specs as the 16g turbo. but either way dont go cheap with your turbo set up cause you will pay for it later! like i did!
Old Mar 15, 2009 | 07:05 PM
scikotictc232's Avatar
not trying to be a dick. but it does not look like you should be going turbo just yet. if i were you i would spend countless hours researching on here. save up your money and do it right the first time. fuel and management. dont risk it. if you dont know what turbo to run though, thats not good for your car or you. it might just go pop.
Old Mar 16, 2009 | 03:09 AM
athlete3232's Avatar
yeah, isnt that alot of HP to hoping for on a stage zero too? i could be wrong... but just dont go cheap, i was considering doing this but im been eerie about it because i dont want to do something wrong. Lol
just remeber, you get what you pay for when it comes 2 boost.... or anything really.
Old Mar 16, 2009 | 03:13 AM
dave2610's Avatar
qft
side note the difference between an untuned or improperly tuned car and a car with a good tune is night and day. Going from the tune the local shop put on to the ptuning tune made me fall in love with my car all over again
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
