quick question about turbo set up.
alright so i just got my car inspected so i can finally get one of my kits on .
ithe one im going to use for now is a zpi stage 0 . was wondering if i would be fine running it at 8psi ? untuned ? and with stock injectors . i have 700cc injectors for my other kit but i dont know if i should run injectors that big on a stage 0 set up ?
any help would be much appreciated
FAIL
700's isn't that big on our cars for 8psi, you will probably be running around the same duty cycle as oem injectors. Meaning the injectors aren't working hard at all and will last longer also by running 700's you have room to turn boost up some.
Bottom line get tuned and upgrade your fuel system to include pump it isn't that much for to gain a lot of reassurance its done right.
ok .
just asking a question . thats all i needed to know .
and i do have a better setup . i just wanted some boost back for now.
and i was already boosted. but the piggy back pooped the bead so i cant run my original kit . so i was just going to run my stage 0 i had here .
but thanks for everything .
somethings to remember when it comes to engine and injector size:
1. is your fuel pump sufficient for what you need
2. is your fuel lines sufficient for what you need
3. do you need a adjustable fuel pressure regulator
4. There is a calculation for RPM of your engine to determine the max possible injection pulse with you can have at a certain RPM. I don't remember the exact calculation but it takes into factor engine cylinders, cycles (4 stroke), and rpm. Even though you think you may have big enough injectors you can use this determination to see if you really do at higher rpm ranges. For example you determine max pulse width at 6500rpm can only be 4ms and you are running lean and need to richen it up but you are running 4ms then you will need to see if it is possible to up your fuel pressure if not then you will need bigger injectors.
my06tc
Jun 25, 2015 12:18 AM
spawnconnery
Dec 18, 2014 08:38 PM
