RC Injectors Install?
Old Oct 28, 2007 | 12:37 AM
olaHalo's Avatar
Default RC Injectors Install?
im getting ready to put my 650 RC injectors (with the clips) on my car. but im not exactly sure how to do it.
it looks like there are just to bolts keeping the fuel rail on. is that true?
so pretty much i just take the fuel rail off, pop the old injectors out, put the new ones in, and connect the wires?
im sort of a "figure it out as you go" kinda guy
any help would be great
thanks
btw if it goes smooth ill be tuned tomorrow!!!!!!!
Old Oct 28, 2007 | 01:15 AM
malloynx's Avatar
injectors are only held in from the fuel rail. remove fuel rail and the injectors will come right out. there only held in the intake manifold with o-rings.
be sure to install new o-rings and lubricate them with a bit of vasoline before installation.
if you have to install new clips, be sure to solder/shirkwrap and not crimp.
Old Oct 28, 2007 | 02:27 AM
Mr_Meaty's Avatar
This is taken from the DEZOD turbo kit install manual, available on their tech notes sections:
http://www.dezod.com/tech_notes.cfm
Look at the back of the motor.
d.
Unplug all four harness going to the fuel injectors.
e.
Remove the 2 12mm nuts that hold the fuel rail onto the block.
f.
BE CAREFUL!! Make sure you have rags ready because there will be some fuel coming out when you do the next step.
g.
Slowly and gently pull the fuel rail off of the block. You’ll notice it’s attached to a hard line, so don’t bend the rail around.
h.
Once the fuel rail is loose, remove the stock 4 fuel injectors.
i.
NOTE-Newer Dezod systems include plug and play fuel injectors, which do not require cutting or modification. Plug in and go! Skip to Step 14.
i.
Cut off the OEM fuel injector harnesses
j.
Use the supplied new harnesses, and the supplied connectors, and make the new harness system. This part is tricky. Take your time and carefully look at what you’re doing because it’s easy to do it incorrectly.
k.
l.
Install the new RC Engineering injectors with the OEM O-rings. Do not use the supplied RC ones, they do not seal properly.
m.
Place the fuel rail back on, and tighten it down with the 12mm wrench.
n.
Plug the fuel injector harness back in.
o.
p.
Leave the cover off so you can check for leaks when you first start the engine
If you download thier manual, it's got pictures too!
Old Oct 28, 2007 | 08:26 AM
olaHalo's Avatar
thanks guys. why do i need to put vasoline on the new O rings?
Old Oct 28, 2007 | 01:30 PM
rozz-tC's Avatar
so they seal, the only thing keeping the gas from coming out is that o-ring, vasoline will condition it and help it make a good seal
Old Oct 28, 2007 | 03:39 PM
malloynx's Avatar
yea, also it's never good to install o-rings dry. there is a possibiblity they won't seat correct or they can tear, etc.. they just need a very light film of lube
Old Nov 5, 2007 | 07:23 PM
griff's Avatar
so does it matter which wire to soldier to which , or are they not polarity sensitive. I got a black and an oragne factory, but I have two blackws for my RC clips
Old Nov 5, 2007 | 07:29 PM
aen's Avatar
aen
thats the same way i got it and the same way halo has it too
i reasoned that the stock injectors have the indention on the clip itself facing upwards so i did the same on the RC clips.
Old Nov 5, 2007 | 10:35 PM
griff's Avatar
so you jes kept the wires on the same side they were origananly ?? good idea
Old Nov 5, 2007 | 11:44 PM
aen's Avatar
aen
well, my car runs so it works lol.
=P
SuBSiN
Mar 13, 2015 04:02 AM
k1114
Mar 6, 2015 03:43 PM
Frustratez
Feb 26, 2015 04:03 PM
B_Real45
Feb 23, 2015 07:33 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
