s/c feels bogged
Alrite i just had my s/c installed yesterday and it was running fine and everything last night but today when i went to work after about 3500RPMS in 1st,2nd,3rd the car feels like it goes nowhere like it bogs. Like extreme turbo lag.
any ideas? thanks ahead Steven |
take the negative terminal off the battery for about 10 minutes, then go for a drive, takes a few blocks for the ecu to readjust itself. See if that helps.
Originally Posted by gompka
(Post 3442558)
i sent u a PM too right now |
Check your hoses. That happened to me just before the charge pipe popped off.
ok will do
thanks |
Sounds like the ECU is till in re-learn mode, it takes a couple of miles before it goes back to normal.
the car feels like i am not boosting anything
like im getting held back alot pass 4K rpms |
Bump
Originally Posted by ProMark
(Post 3443426)
like im getting held back alot pass 4K rpms did you try what any of the ppl above have suggested... its simple to figure out whats happening right now... your being put into limp mode for some reason some reasons could be... - you blew a pipe off and need to re-attach it...(disconnect battery after this for 30 seconds) - reset the ecu (undo battery for 30 seconds) - did you get the trd flash yet? - bad maf sensor - vacuum leak - boost leak somewhere if u find any of theses fix it then reset the ecu by disconnecting the battery now stop saying u will do this and go actually do it :pray: |
Could be the plugs? there is another guy on here who said the dealer put in the wrong plugs.
Originally Posted by gwtc
(Post 3443682)
have you freaking tried anything that we have told you godness even my neice who is 3 can do those simple things...and yes shee can cuz i have had her do these things for me b4
Originally Posted by cburglb34
(Post 3444194)
im gonna go over all the pipping again just to triple check i didnt c anything bad it has to be a leak somewhere that i have not found |
(Post 3444219)
yea man i have
im gonna go over all the pipping again just to triple check i didnt c anything bad it has to be a leak somewhere that i have not found look around the bypass valve thats a spot ppl over look... |
just threw a Check engine light
(Post 3444716)
(Post 3444833)
In a way thats good, now you'll have a code to go by, go get it read at your dealer.
i was going to try like pep boys or something |
go to autozone or something like that before you go to the dealer.
make sure your not just loosing traction especially in the cold, I know when Im just slightly spinning it feels like im bogging bad
(Post 3444872)
does anyone know what they charge?
