s/c feels bogged
Old Jan 24, 2010 | 05:11 PM
ProMark's Avatar
Default s/c feels bogged
Alrite i just had my s/c installed yesterday and it was running fine and everything last night but today when i went to work after about 3500RPMS in 1st,2nd,3rd the car feels like it goes nowhere like it bogs. Like extreme turbo lag.
any ideas?
thanks ahead
Steven
Old Jan 24, 2010 | 06:09 PM
gompka's Avatar
take the negative terminal off the battery for about 10 minutes, then go for a drive, takes a few blocks for the ecu to readjust itself. See if that helps.
Old Jan 24, 2010 | 06:14 PM
ProMark's Avatar
thanks i'll try that when im off
i sent u a PM too right now
Old Jan 24, 2010 | 09:54 PM
BLUEMEANIE's Avatar
Team Hamster
Check your hoses. That happened to me just before the charge pipe popped off.
Old Jan 24, 2010 | 10:36 PM
ProMark's Avatar
ok will do
thanks
Old Jan 25, 2010 | 03:06 AM
gwtc's Avatar
Sounds like the ECU is till in re-learn mode, it takes a couple of miles before it goes back to normal.
Old Jan 25, 2010 | 06:19 AM
ProMark's Avatar
the car feels like i am not boosting anything
like im getting held back alot pass 4K rpms
Old Jan 25, 2010 | 02:15 PM
ProMark's Avatar
Bump
Old Jan 25, 2010 | 02:23 PM
cburglb34's Avatar
did you try what any of the ppl above have suggested...
its simple to figure out whats happening right now... your being put into limp mode for some reason
some reasons could be...
- you blew a pipe off and need to re-attach it...(disconnect battery after this for 30 seconds)
- reset the ecu (undo battery for 30 seconds)
- did you get the trd flash yet?
- bad maf sensor
- vacuum leak
- boost leak somewhere
if u find any of theses fix it then reset the ecu by disconnecting the battery
now stop saying u will do this and go actually do it
Old Jan 25, 2010 | 03:19 PM
gwtc's Avatar
Could be the plugs? there is another guy on here who said the dealer put in the wrong plugs.
Old Jan 25, 2010 | 09:34 PM
ProMark's Avatar
they're brand new Denso ik22
Old Jan 25, 2010 | 10:16 PM
cburglb34's Avatar
have you freaking tried anything that we have told you godness even my neice who is 3 can do those simple things...and yes shee can cuz i have had her do these things for me b4
Old Jan 25, 2010 | 10:34 PM
ProMark's Avatar
yea man i have
im gonna go over all the pipping again just to triple check i didnt c anything bad
it has to be a leak somewhere that i have not found
Old Jan 25, 2010 | 10:35 PM
cburglb34's Avatar
yea man i have
look around the bypass valve thats a spot ppl over look...
Old Jan 26, 2010 | 03:58 AM
ProMark's Avatar
just threw a Check engine light
Old Jan 26, 2010 | 04:55 AM
gwtc's Avatar
In a way thats good, now you'll have a code to go by, go get it read at your dealer.
Old Jan 26, 2010 | 05:13 AM
ProMark's Avatar
does anyone know what they charge?
i was going to try like pep boys or something
Old Jan 26, 2010 | 06:13 AM
DJ08tC's Avatar
go to autozone or something like that before you go to the dealer.
Old Jan 26, 2010 | 03:07 PM
Blue_TC_Man's Avatar
make sure your not just loosing traction especially in the cold, I know when Im just slightly spinning it feels like im bogging bad
Old Jan 26, 2010 | 05:08 PM
gwtc's Avatar
The dealer should not charge you anything just for checking it. I went to Autozone and they no longer check them for you(at least the one I went to), I think Pepboys will but not sure if they charge or not.
