S1 Install
Old Feb 26, 2008 | 11:37 PM
Scoobasteve4132's Avatar
Default S1 Install
So it looks like I could have my new Dezod S1 kit as soon as this weekend... Thanks Paul @ Dezod!!!
In that case, I was curious what extras gaskets, etc I should pick up...
Im gonna get an oil pan and exhaust manifold gasket... Ive got plenty of the red gasket sealant... But just wanted to see what else I should pick up prior to the install...
I already have Motul engine cleaner, oil and filter ready to go... Anything else?
If you can think of anything, please let me know!... Thanks in advance...
Old Feb 27, 2008 | 01:05 AM
rhythmnsmoke's Avatar
Music City Scions
Where did you pick up the Motul Engine clean?
Old Feb 27, 2008 | 01:54 AM
Mach V motorsports.... MachV.com
Old Feb 27, 2008 | 01:56 AM
I googled it, and came up with them.. They are a little bit more expensive, but Ive been to their shop before so trust them a little bit more
Old Feb 27, 2008 | 03:41 PM
Has anyone replaced the oil pan gasket before?... I called our local dealership to get one and they said it doesnt have one... Just wanted to verify this... Thanks!
Old Feb 27, 2008 | 03:45 PM
paul_dezod's Avatar
Scionetics
KAD
Just some basic hand tools. and such as well. I think MOST of your kit left yesterday and the remainder should leave today, tomorrow or Friday. Logistics have been a nightmare here.
Old Feb 27, 2008 | 04:03 PM
Yea I know what you mean... Sorta what I do, lol... Thanks btw, you've been some awesome help...
Old Feb 27, 2008 | 04:20 PM
Mightygnu's Avatar
Vacuum Line, your going to need it.
Old Feb 27, 2008 | 04:23 PM
A new line?... Or does it come w/ the kit?... Im ordering a block from TT... Anything else needed?... Besides the fittings which I can get locally?
Old Feb 27, 2008 | 04:25 PM
ippskidder's Avatar
1UP Crew
The oil pan uses a really sticky black adhesive (USE GLOVES! lol). When I did my turbo install I got it from the dealer. Sorry I don't have the part#.
Old Feb 27, 2008 | 04:28 PM
java09's Avatar
just walk in toyota and say "oil pan gasket sealant" thats exactly whats its called and yes use gloves, after you apply it tighten it down half way let it sit and hour, then tighten it all the way down and you wont have any leaks! good luck with the install!
Old Feb 27, 2008 | 04:33 PM
ippskidder's Avatar
1UP Crew
Don't forget the little clamps to hold down the vaccum line to the fitting. I neglected to do that on 2 vaccum lines and they popped out under boost. When I first did the install I was a noob and forgot to do that lol.
Old Feb 27, 2008 | 04:41 PM
any recommendations for clamps
Old Feb 27, 2008 | 04:43 PM
Joe_Dezod's Avatar
I used a propane torch set to low to heat the gasket up around the oil pan. That makes it a little easier to pry the pan off.
The only time you NEED a power tool is for drilling 3/8" holes on the lower frame support for mounting the intercooler.
The oil pan, wastegate, and engine cover use 10mm bolts.
T-bolt clamps use 11mm bolts.
Fuel rail and turbo manifold studs use 12mm.
Turbo downpipe and supplied bolts for wastegate use 13mm.
Exhaust/S-Pipe uses a combination of 14mm and 15mm bolts/nuts.
Buy at least 6' of 3/16" or 3/8". I would honestly recommend getting two 6' packs just in case.
The injectors come with a grease for installation, make sure you use it.
Off the top of my head, not sure what else you'd need.
Did you buy the massive drill bit needed for the oil return fitting?
Old Feb 27, 2008 | 04:44 PM
Joe_Dezod's Avatar
The kit comes with all the T-bolt clamps you need. They use a 11mm nut. The worm-gear style clamps are for your intake pipe.
Old Feb 27, 2008 | 04:53 PM
ippskidder's Avatar
1UP Crew
For the vacuum line, I think I used 3-5mm clamps, don't remember the size off the top of my head....
hmm, i'm pretty sure I used tie wraps on a few, that were to small for the metal clamps to hold on to.
Its been a while since I worried about the vacuum lines
I've been pushing 10psi for a while, and no problems.
Old Feb 27, 2008 | 06:02 PM
Music City Scions
Aren't the bolts torqued to a certain ftlbs?
Old Feb 27, 2008 | 06:13 PM
Joe_Dezod's Avatar
Here you guys go!
Please look carefully at the torque specs. It is in inch-lb, NOT ft-lb. This translates to 6.7 ft-lbs for the oil pan bolts. The oil drain bolt is to be torqued to 30 ft-lb, or 40 Nm (408 KGF-CM)
You're welcome!
Old Feb 27, 2008 | 06:15 PM
Music City Scions
Nice!
Old Feb 27, 2008 | 06:16 PM
Thanks!
