scion_andrew official turbo thread
Finally started to install my kit tonight haha only installed One part but im excited!
treadstone mani
garett 57 trim turbo
turbonetics wastegate
greddy rs bov
greddy ic piping
ebay intercooler
dezod vac block
550cc injectors emanage blue
dezod pnp harness
an 3in dp back exhaust with a carbon ti!
Will keep updated as i finish it up!
treadstone mani
greddy rs bov
greddy ic piping
ebay intercooler
dezod vac block
dezod pnp harness
^thanx, but i have a question my turbo intake tube is bigger that the turbo by a little bit would it be ok if i jus clamp it down to fit or should i get a smaller tube?
you mean coupler? depending on how much bigger the coupler is it could cause issues. try it out and see what happens.
OK this is how it looks its not much bigger but its deff bigger as u can see in the pic, how do i know which coupler to order?
Also wat is the wire im holdin in my hand i jus plug in the pnp haness correct? an dont use the wire im holding???
Thanks for the help this is my 1st turbo instal
what travis said..
the wire i think your holding is the universal harness...not sure since iv never delt with the greddy brand engine management, looks like you would just go with the pnp harness.
something like this....find out exactly the od of each and get the correct coupler
http://www.sfxperformance.com/parts/SPT8772.htm
http://www.streetsideauto.com/produc...NON&Reset=True
http://www.streetimports.com/products.asp?catid=179
hey that wire is the universal HARDWIRE harness, put it aside and save it incase the PNP for somereason goes bad..
as for ordering the right coupler...get a tape measure and measure the size of the intake pipe...prop is a 2.75 or 3inch
and then measure the turbo inlet its prob like 2.5
then go on ebay or something and get a 2.75in to 2.5 inch coupler or a 3-2.5
freakin andrew!!!! i thought you had this kit installed a long time ago! what kit is it???? i hate you and bobby now! both of you are tubo'd and im still n/a!! hopefully on income tax i can buy a kit then we'll all race eachother again! lol when are you coming down here? you and bobby should race and see who's faster now....
