ScionGT35R' new numbers +500 on pump gas
Old 03-23-2008, 05:52 PM
  #41
Mecanica_Pito's Avatar
Originally Posted by etsnet
That sucks! Believe me I know.lol You think it could have had anything to do with the last problem? What bearing are you using?
I don't think, but, at this point is a possibility. We used ACL bearings.
Pito
Mecanica_Pito is offline
Old 03-23-2008, 06:09 PM
  #42
TCFROEZEL's Avatar
Pito
Pito you remember what i told you in a past message.
i would have replaced the crankshaft.
i have had many bad experiences with those type of spun bering in the past.
maybe you will not trust my advice but i am talking about experience.
Go with a new crankshaft, or one that has no spun bering.
and a NEW oil pump. and you should be set man.
a NEW oil pump is very important as goes for the new crankshaft.
that is bad to hear man more down time for the SCIONGT35R.
hope everything comes out as planned.
Which Bf Goodridge tires were you using ? are those Semie Slicks ?
TCFROEZEL is offline
Old 03-23-2008, 06:46 PM
  #43
Music City Scions
rhythmnsmoke's Avatar
^^He said drag radials, so no not semi Slicks. But that does truly suck. Did you guys get to make ANY passes?
rhythmnsmoke is offline
Old 03-23-2008, 07:02 PM
  #44
ScionGT35R's Avatar
These are the tires.
http://www.bfgoodrichtires.com/overv...dial/1161.html
We make a few passes. The best was 9.0 on the 1/8 mile track with a lot of wheel spin.
ScionGT35R is offline
Old 03-23-2008, 07:54 PM
  #45
Guest
Guest
Posts: n/a
Pito
The only ACL bearing available at this time is the ACL Aluglide bearings. These are designed as OEM-quality replacement bearings. ACL manufacturers OEM bearings for many car manufacturers. These bearings are not designed to handle that kind of load, especially with the increase load from upping the rev limt.
We will be releasing main and rod bearings around June/July for the 2az-fe motor. These bearings are ACL Race Series bearings. These bearings are purpose-built racing tri-metal bearings with hardened steel backing, improved oiling groove, chamfer edges, and increae crush. They are designed to handle the increased rpm and load. In addition to that we will be releasing our Ptuning billet chromoly main caps with Ptuning/ARP2000 main studs. Down the road we may offer a billet main cap girdle system to further strengthen the main cap assembly, but it will require machining the lower block assembly or an entirely new casted lower block assembly--this can get expensive.
MrC
Old 03-23-2008, 10:57 PM
  #46
Music City Scions
Yeah, those are the ones I ran too. 9.0.... I can only imagine the traction issues with that then.
Old 03-25-2008, 06:56 PM
  #47
krazylowgsx's Avatar
ahh.. the joys of boost! you guys sure don't waste any time tearing into that car when thiers a problem.. I'll give you that! some people get so fed up and just give up!
krazylowgsx is offline
Old 03-25-2008, 07:00 PM
  #48
ScionGT35R's Avatar
I almost did!!!
I was thinking on going back to N/A or NOS.
Old 03-25-2008, 07:09 PM
  #49
Originally Posted by krazylowgsx
ahh.. the joys of boost! you guys sure don't waste any time tearing into that car when thiers a problem. I'll give you that!
We certainly do that. It is very easy for him. The problem is putting it back together !!
Just between you and me ........... Roberto has seriously thought about it !!!
Pito
Old 03-25-2008, 07:21 PM
  #50
brett561tc's Avatar
what were your trap speeds?
brett561tc is offline
Old 03-25-2008, 09:21 PM
  #51
riceburner's Avatar
ahhhhman!!!!!!!!that things has got to be a BEAST!!!!!!!
nice ride!!!!!
riceburner is offline
Old 04-28-2008, 07:12 PM
  #52
t_urbo_C_harged's Avatar
Pito
MrC
you guys are awesome, keep the scion market growing!
t_urbo_C_harged is offline
Old 04-28-2008, 07:23 PM
  #53
Guru's Avatar
To be honest with you these motors are very very strong. I think we see a lot of blown motors due to bad tuning in this community.
Guru is offline
Old 04-28-2008, 07:28 PM
  #54
KAD
carbon_ninja's Avatar
awesome guys keep up the boost i mean good work lol
carbon_ninja is offline
Old 04-28-2008, 10:14 PM
  #55
TCFROEZEL's Avatar
I agree with GURU.
BTW there is one Stock scion in P.R. who made.
It made 380 HP on 17 PSI. ( stock bottom )
Old 04-28-2008, 10:52 PM
  #56
Originally Posted by TCFROEZEL
I agree with GURU.
We made 356HP on 16 psi on stock head and stock bottom and we are from PR. Maybe you are refering to us!
Pito
Old 04-28-2008, 11:06 PM
  #57
The tuning is OK. The numbers don't lie and we are still using stock TB, stock cams and a piggy-back.
The engine failed because of a very stupid detail probably caused by me in addition to some bad luck!
Turned out that a strip of silicone sealant got loose between the upper oil pan and the block and ended up completely blocking the oil passage to one of the main bearings.
We already have a new crankshaft, HV oil pump and bearings! I just have to convince Roberto to not give up on the car and go back to N/A.....and so far it is not working.......
Pito
Old 04-29-2008, 12:02 AM
  #58
ScionGT35R's Avatar
I agree with GURU.
Pito
No!!! He is talking about Jotech. It was 380whp @18 psi and 2 weeks after the engine blows!!!!They were using and apex neo. After that they use another engine with pistons and rods and at 22psi they made 420whp. After that they went back to N/A and sold the car.
Old 04-29-2008, 12:04 AM
  #59
RSracer's Avatar
I talk to Horizon racing...they use the OEM oil pump on their SFWD car. They told me to only use the stock pump and do NOT shim it.. Saw you got an HV oil pump so i thought i would just passing on that info.
RSracer is offline
Old 04-29-2008, 01:35 AM
  #60
Music City Scions
I agree with GURU.
Pito
Wait, so the 739whp tC they have now is NOT the one that use to make 533whp? Cause I remember reading that it was the same car.
Quick Reply: ScionGT35R' new numbers +500 on pump gas
