Sealant for oil pan?
Old Apr 19, 2008 | 05:20 PM
SoFloTC's Avatar
Default Sealant for oil pan?
hey what kind of sealant should i get for the oil pan to put it back on?
anything i can buy at a local homedepot or lowes or autozone or anything?
or should i just go to a dealership and ask for toyota sealant?
Old Apr 19, 2008 | 05:31 PM
Ace83's Avatar
Ronin Scion
you can buy red rtv or go to the dealer and ask for oil pan sealant, they sell it for like 11 or 16 bucks..
Old Apr 19, 2008 | 05:32 PM
coryjames's Avatar
i use i forgot what its called but its on a brush in a can its what i used for my vw bug but silicone will work fine
Old Apr 19, 2008 | 05:41 PM
Scoobasteve4132's Avatar
red rtv is good... it's hi-temp rtv... you can pick that up at pretty much any autoplace..
Old Apr 19, 2008 | 06:16 PM
SoFloTC's Avatar
so theres virtually no difference between red rtv and the dealers sealant?
Old Apr 19, 2008 | 06:21 PM
Joe_Dezod's Avatar
It's different, but the red RTV works very well. It's also easier to remove again if you ever need to take the oil pan off.
Old Apr 19, 2008 | 06:24 PM
SoFloTC's Avatar
alrightyyyy ... gotta get that today sumtime...
joe is there anything else u suggest to pickup that would help with the install.. i got oil, exhaust manifold gasket, getting red rtv.... anything else?
Old Apr 19, 2008 | 06:27 PM
coryjames's Avatar
red rvt is the same as other rtv its just red so its visible in construction apps for fire blocks but from clear to red generally there is no difference
Old Apr 19, 2008 | 06:37 PM
Joe_Dezod's Avatar
Do you have the oil filter and the necessary drill bits? Having an 10mm (battery, wastegate), 11mm (t-bolt clamps), 12mm (manifold bolts), 13mm (turbo bolts) 14mm, and 15mm wrench will definitely make things easier for you.
Having a good strong drill with black oxide bits will drill much faster than plated or pilot point drill bits. They are also less prone to snapping. Make sure you have a couple packages of vacuum lines and the necessary vacuum T's as well.
Old Apr 19, 2008 | 07:07 PM
SoFloTC's Avatar
what do i need the drill and the bits for? just the oil pan?
i think ima just have the line welded.
Old Apr 19, 2008 | 08:37 PM
coryjames's Avatar
the oil pan is aluminum am i correct i would get a step bit also know as a uni bit pricey but near un breakable i use mine often to drill into concrete and it still holds up
Old Apr 19, 2008 | 08:40 PM
Syldrin's Avatar
Toyota Black is some of the best sealant you can get. i'd suggest using OEM sealant.
Old Apr 19, 2008 | 08:43 PM
coryjames's Avatar
ill use my vw stuff it held the case together no leaks and i still have it if you need some jay its really nice stuff what i used to hold my vw together
Old Apr 19, 2008 | 08:53 PM
Syldrin's Avatar
Joe has some he's giving me.
Old Apr 19, 2008 | 09:05 PM
yeldak's Avatar
I don't know what the toyota FIPG is made of, but that stuff is ridiculously strong. I've heard lots of stories about guys bending oil pans before that stuff gave out. (while they were trying to pry them off)
Old Apr 19, 2008 | 09:07 PM
SoFloTC's Avatar
damn
Old Apr 19, 2008 | 09:08 PM
Syldrin's Avatar
Well think of the lawsuit toyota would have if your oilpan fell off in the middle of the road?
Old Apr 19, 2008 | 10:02 PM
Lol, yea... Yea many have to heat it up to the flange to take it off...
Old Apr 20, 2008 | 12:28 AM
yamaha16bw's Avatar
I used a blow torch to remove my pan....lol. I used red RTV to re-install it. Been fine for 2 years now.
Old Apr 20, 2008 | 12:52 AM
Me too!...
