secondary 02 sensor
Old Oct 14, 2010 | 09:02 PM
twinscrollinxrs's Avatar
Default secondary 02 sensor
Can i run my aem uego to the secondary 02 sensor bung?? just curious, if not, i gotta weld another bung
Old Oct 14, 2010 | 09:06 PM
cavalierkid888's Avatar
Sure ya can, but doing so means you will not have the factory secondary 02 sensor hooked up which will cause you to throw a CEL.
Old Oct 14, 2010 | 09:10 PM
crush02342002's Avatar
yep..you can but like as stated it will throw a code
Old Oct 14, 2010 | 09:32 PM
ah, forget that,ill just weld on the bung. i was trying to cheat because my welding sucks, thought i could cut a corner
Old Oct 14, 2010 | 11:19 PM
johnnyb305mia's Avatar
Dont cut corners do things right the first time this is comming from experience it will cost more in the long run if u take short cuts
SENT FROM MY DROID
Old Oct 15, 2010 | 12:32 AM
Syldrin's Avatar
just remove your spipe and take it to a exhaust shop it will cost like 30 bux tops. if you cant afford that you might not want to boost. you'll be spending a lot more then that
Old Oct 15, 2010 | 12:48 AM
m6ar2cel6oTC's Avatar
SENT FROM MY DROID
this!!!
MeDizzy
Oct 8, 2015 03:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
prescottn
Sep 22, 2015 01:30 PM
gqdabien
Sep 17, 2015 09:23 PM
Topfueltom69
Sep 6, 2015 05:25 PM
