setting up knock sensor on emanage ultimate?
Old Nov 8, 2008 | 04:29 PM
rozz-tC's Avatar
Default setting up knock sensor on emanage ultimate?
Anyone know the correct settings in EMU to read knock? I have a PnP harness which supports this, but do not know what sensor type or freq to choose.
Old Jan 26, 2009 | 11:10 PM
gingles's Avatar
bringing back the dead...also interested in this
Old Jan 26, 2009 | 11:13 PM
B_Real45's Avatar
What are the options? Maybe we can figure this out.
Old Jan 26, 2009 | 11:44 PM
Ace83's Avatar
Ronin Scion
It would be great if you can tap an LED bulb that blinks when knock voltage is detected
Old Jan 26, 2009 | 11:54 PM
rozz-tC's Avatar
the options are
resonant and non resonant
and then the frequency, not sure what ours is, i know my harness is supposed to be setup for knock
Old Jan 26, 2009 | 11:57 PM
gingles's Avatar
we need to know the frequency of it though...hrmmm
Old Feb 2, 2009 | 12:31 AM
gingles's Avatar
still nothing?...come on guys
Old Feb 2, 2009 | 02:10 AM
rhythmnsmoke's Avatar
Music City Scions
I have the PnP harness as well. I think PTuning is probably the most versed in this matter, hopefully they will weigh in.
Old Feb 11, 2009 | 04:23 AM
gingles's Avatar
bump to the top...ive been doing research for about 2 days and cant find anything...someones got to know
Old Feb 11, 2009 | 04:55 AM
gingles's Avatar
so far this is the only link ive found that might be of some help
http://www.phormula.co.uk/KnockCalculator.aspx
Old Feb 11, 2009 | 04:58 AM
gingles's Avatar
and this one....so im thinking we have a resonant knock sensor at 6.5 hrz
http://www.freepatentsonline.com/4964294.html
by no means am i reliable for anything that goes wrong....im just trying to answer a question i need answered as well as other people with the emanage
Old Feb 11, 2009 | 05:08 AM
gingles's Avatar
well hell it might be non resonant...hopefully paul or ptuning will chime in
Old Feb 12, 2009 | 11:09 PM
gingles's Avatar
its non resonant and is the same as the 02+celica gt-s'.....still unsure of frequency
Old Feb 13, 2009 | 02:33 AM
rozz-tC's Avatar
ill try that tomorrow, ill be getting tuned anyway. Ill mess with some of the frequency and see if i can get anything to show up
Old Feb 13, 2009 | 03:52 AM
gingles's Avatar
dude if you can that would be awesome.....i just cant get on a dyno around here quick enough....also make sure to list what else you have done.......like std bore or oversized bore...
Old Dec 15, 2010 | 07:15 PM
thendawg's Avatar
Brining this back from the dead... Im hooking up my ultimate soon and have never found an exact answer on this. From what Im thinking, it should be non-res around 6.4KHZ (I have 89mm piston)
Old Dec 15, 2010 | 07:30 PM
crush02342002's Avatar
http://www.dezod.com/files/ECU%20pinouts----.pdf
mayhelp somewhat
Old Dec 15, 2010 | 07:47 PM
thendawg's Avatar
Soooo I randomly found this.... Our knock sensor is deff non-resonant -
Knock Sensor
Built-in Piezoelectric Type
(Non-resonant Type/ Flat Type
Now, we just have to figure out the freq at which knock occurs, which should be able to be calculated from the bore size...
According to that calculator it would be 6.4KHz - Ill def be testing this once I have my Ultimate in soon
Old Dec 15, 2010 | 08:31 PM
sweet...let us know
Old Dec 15, 2010 | 10:38 PM
m6ar2cel6oTC's Avatar
Knock Sensor
better keep us updated
